Discuss
Garbage Disposal is 'squeeling' high pitch noise & is spitting up water
 in
Garbage Disposer Repair
Hi - great site by the way....I read all the posts before I posted this so as not to repeat -
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Garbage Disposal is 'squeeling' high pitch noise & is spitting up water
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-24-2008, 04:11 PM
LeahQ LeahQ is offline
Junior Member
LeahQ is on a distinguished road
Default Garbage Disposal is 'squeeling' high pitch noise & is spitting up water
Model Number: 6045   Brand: Kenmore   Age: Less than 1 year
Hi - great site by the way....I read all the posts before I posted this so as not to repeat - but my disposal has been making such a horrid high-pitched noise, and just noticed a burnt rubber smell now, and now the water won't drain. I turned it off naturally, cleared out the un-chewed food, the water is still draining slowly - your thoughts?
Power works great, have always used water, treated garbage disposal nicely, etc....thanks for your assistance!
Leah
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-25-2008, 11:33 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Leah,
The first problem is a clogged drain line which has nothing to do with the garbage disposal. You have to call a plumber to unclog it.
The high pitched noise could be because of a small hard foreign object stuck inside.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Garbage disposal Andrea Higgins Garbage Disposer Repair 0 03-11-2008 11:53 AM
Garbage disposal Patty65 Garbage Disposer Repair 0 03-07-2008 11:30 AM
garbage disposal Dianne Garbage Disposer Repair 1 02-11-2008 01:45 PM
Whirlpool Imperial Washer making high pitch noise Minickhk Washer Repair 0 01-11-2008 07:36 AM
Help with Garbage disposal sounds please zuma Garbage Disposer Repair 1 08-11-2007 05:20 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
