Discuss
InSinkErator Disposal clogged
 in
Garbage Disposer Repair
I boiled and softened King Crab legs and chopped the shells and fed them into my garbage disposal. The blades
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » InSinkErator Disposal clogged
  #1 (permalink)
Old 03-21-2008, 09:13 PM
djramb2 djramb2 is offline
Junior Member
djramb2 is on a distinguished road
Default InSinkErator Disposal clogged
Model Number: 777ss   Brand: -other-   Age: Less than 1 year
I boiled and softened King Crab legs and chopped the shells and fed them into my garbage disposal. The blades spin perfectly, but the water will not go down. I have tried vigariously plunging (hand plunger) many times with no results.
Any suggestions?
Related Models
Maytag 77C Dryer - Gas
Magic Chef 77E-5CXWM9 Walloven - S/c Mwave Ele
Magic Chef 77E-5EXWW Walloven - S/c Ele
Magic Chef 77EN-5CXWM9 Walloven - S/c Mwave Ele
Magic Chef 77EN-5EXWW Walloven - S/c Ele
Magic Chef 77F-5EVWM
Magic Chef 77F-5EVWW
Magic Chef 77F-5EXWM
Magic Chef 77F-5EXWM9
Magic Chef 77F-5EXWW
Magic Chef 77FA-5EVWM
Magic Chef 77FA-5EVWW
Magic Chef 77FA-5EXWM
Magic Chef 77FA-5EXWW
Magic Chef 77FK-5EVWM
Magic Chef 77FK-5EVWW
Magic Chef 77FK-5EXWM Walloven - S/c Mwave Ele
Magic Chef 77FK-5EXWW Walloven - S/c Ele
Magic Chef 77FN-5EVWM Walloven - S/c Mwave Ele
Magic Chef 77FN-5EVWW Walloven - S/c Ele
Magic Chef 77FN-5EXWM
Magic Chef 77FN-5EXWM9 Walloven - S/c Mwave Ele
Magic Chef 77FN-5EXWW
Magic Chef 77J-5EXWM
Magic Chef 77JK-5EXWM Walloven - S/c Mwave Ele
Magic Chef 77JN-5EVWM Walloven - S/c Mwave Ele
Magic Chef 7858XRA Walloven - S/c Dbl Oven Ele
Magic Chef 7858XRW Walloven - S/c Dbl Oven Ele
Magic Chef 7858XUA Walloven - S/c Dbl Oven Ele
Magic Chef 7858XUW Walloven - S/c Dbl Oven Ele
Magic Chef 7858XVA Walloven - S/c Dbl Oven Ele
Magic Chef 7858XVW Walloven - S/c Dbl Oven Ele
Frigidaire 787 FRIGIDAIRE DISHWASHER 24"
Magic Chef 7898VAD Range - S/c Mwave Ele
Magic Chef 7898VAV Range - S/c Mwave Ele
Magic Chef 7898VRA Range - S/c Mwave Ele
Magic Chef 7898VRV Range - S/c Mwave Ele
Magic Chef 7898VVV Range - S/c Mwave Ele
Magic Chef 7898XRA Range - S/c Mwave Ele
Magic Chef 7898XRW Range - S/c Mwave Ele
Magic Chef 7898XVA Range - S/c Mwave Ele
Kenmore 790.1  HAIR CLIPPERS
Kenmore 790.2  HAIR CLIPPERS
Kenmore 790.3  HAIR CLIPPERS
Kenmore 790.330020  GAS COOKTOP
Kenmore 790.33002990  GAS COOKTOP
Kenmore 790.33002991  GAS COOKTOP
Kenmore 790.330030  GAS COOKTOP
Kenmore 790.33003990  GAS COOKTOP
Kenmore 790.33003991  GAS COOKTOP
Kenmore 790.330040  GAS COOKTOP
Kenmore 790.33004990  GAS COOKTOP
Kenmore 790.33004991  GAS COOKTOP
Kenmore 790.330090  GAS COOKTOP
Kenmore 790.33009990  GAS COOKTOP
Kenmore 790.33009991  GAS COOKTOP
Kenmore 790.330120  GAS COOKTOP
Kenmore 790.33012990  GAS COOKTOP
Kenmore 790.33012991  GAS COOKTOP
Kenmore 790.330130  GAS COOKTOP
Kenmore 790.33013990  GAS COOKTOP
Kenmore 790.33013991  GAS COOKTOP
Kenmore 790.330140  GAS COOKTOP
Kenmore 790.33014990  GAS COOKTOP
Kenmore 790.33014991  GAS COOKTOP
Kenmore 790.330190  GAS COOKTOP
Kenmore 790.33019990  GAS COOKTOP
Kenmore 790.33019991  GAS COOKTOP
Kenmore 790.33022100  GAS COOKTOP
Kenmore 790.33023100  GAS COOKTOP
Kenmore 790.33024100  GAS COOKTOP
Kenmore 790.33029100  GAS COOKTOP
Kenmore 790.33032100  GAS COOKTOP
Kenmore 790.33033100  GAS COOKTOP
Kenmore 790.33034100  GAS COOKTOP
Kenmore 790.33039100  GAS COOKTOP
Kenmore 790.45702300  GAS RANGE
Kenmore 790.45704300  GAS RANGE
Kenmore 790.45709300  GAS RANGE
Kenmore 790.45712100  DUAL FUEL SIDE-IN RANGE
Kenmore 790.45712102  SEARS/GAS RANGE
Kenmore 790.45712103  SEARS/GAS RANGE
Kenmore 790.45714100  DUAL FUEL SIDE-IN RANGE
Kenmore 790.45714102  SEARS/GAS RANGE
Kenmore 790.45714103  SEARS/GAS RANGE
Kenmore 790.45719100  DUAL FUEL SIDE-IN RANGE
Kenmore 790.45719102  SEARS/GAS RANGE
Kenmore 790.45719103  SEARS/GAS RANGE
Kenmore 790.46132300  GAS RANGE
Kenmore 790.46133300  GAS RANGE
Kenmore 790.46134300  GAS RANGE
Kenmore 790.46139300  GAS RANGE
Kenmore 790.468120  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46812990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46812991  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46812992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46812993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.468130  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813991  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.468140  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46814990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46814992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46814993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.468190  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46819990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46819992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46819993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46832100  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46832101  SEARS/GAS RANGE
Kenmore 790.46832102  SEARS/GAS RANGE
Kenmore 790.46833100  DUAL FUEL RANGE
Kenmore 790.46833101  SEARS/GAS RANGE
Kenmore 790.46833102  SEARS/GAS RANGE
Kenmore 790.46834100  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46834101  SEARS/GAS RANGE
Kenmore 790.46834102  SEARS/GAS RANGE
Kenmore 790.46839100  DUAL FUEL SLIDE-IN RANGE
  #2 (permalink)
Old 03-22-2008, 06:19 AM
bambiblaster bambiblaster is offline
Senior Expert
APP Volunteer
bambiblaster is on a distinguished road
Default
you need to turn off circuit breaker to disposer and remove drain pipe that comes out of it and clean out the clogg
  #3 (permalink)
Old 03-22-2008, 07:04 PM
Junior Member
Default thanks for your advice
Thanks for your advice! I was hoping to avoid removing the drain pipe. To that end I continued plunging for a very long time rather than removing the pipe. The clogg did finally move with plunging.
thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Garbage disposal Patty65 Garbage Disposer Repair 1 05-11-2009 06:20 PM
Garbage disposal Andrea Higgins Garbage Disposer Repair 0 03-11-2008 12:53 PM
garbage disposal Dianne Garbage Disposer Repair 1 02-11-2008 02:45 PM
Clogged defrost drain tube d77n Refrigerator & Freezer Repair 0 12-15-2007 10:30 AM
Will not drain, not clogged Jimmy Washer Repair 1 12-02-2007 11:15 PM
