Discuss
No power to disposal
 in
Garbage Disposer Repair
Disposal stopped. I have done to following troubleshooting: Checked circuit breaker.....was tripped and turned back on. Blades turn in disposal,
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » No power to disposal
  #1 (permalink)
Old 12-01-2009, 01:25 PM
Junior Member
rmarsh1001 is on a distinguished road
Default No power to disposal
Brand: Kenmore   Age: 5 - 10 years
Checked circuit breaker.....was tripped and turned back on. Blades turn in disposal, used 1/4 wrench. Removed debris from disposal. Reset button was pressed.....no luck. Still have no power. Have I burned out my garbage disposal?
Ads By Google
  #2 (permalink)
Old 12-03-2009, 07:05 PM
Junior Member
GiPilot is on a distinguished road
Smile
Unplug the disposal from the receptacle under the sink. Check the receptacle the disposal is plugged into, make sure it has power. If the receptacle works then check the wiring inside the side of the disposal, one of the wire nuts may have come loose or caused a short.
  #3 (permalink)
Old 12-13-2009, 10:37 PM
Junior Member
nobleelectronics is on a distinguished road
Default
might also want to check the GFCI receptical by the sink sometimes the electrician will tie in the garbage disposal outlet to the closest receptical near the sink and sometimes that will trip just something to take a quick peek at
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
garbage disposal Dianne Garbage Disposer Repair 2 02-13-2010 11:12 AM
Disposal Leaking ozone Garbage Disposer Repair 0 09-11-2009 11:24 AM
Cannot remove old disposal samijd Garbage Disposer Repair 2 05-25-2009 07:02 PM
GE garbage disposal Mikark Garbage Disposer Repair 1 01-06-2009 10:57 AM
Garbage disposal Von Garbage Disposer Repair 1 01-05-2009 06:59 AM
