| » Outlet tube on Insinkerator |
Model Number: 77-79 Brand: -other- Age: 5 - 10 years
Hello,
I have an Insinkerator Model 77-79 that was draining slowly. On inspection of the outlet pipe, there is an internal piece of nylon or poly tube that has folded in upon itself causing the outlet to be partially blocked. Is this piece replaceable/needed? It is like a sleeve that is inside the machine between the flange where the outlet pipe connects and the impeller itself. Thank you! Randy C Curry Related Models |
| Display Modes | |
| My Insinkerator leaks! Help! | Gloria Clary | Garbage Disposer Repair | 0 | 07-18-2009 11:59 AM |
| Replacing GE w/Insinkerator? | jlynne68 | Garbage Disposer Repair | 1 | 01-24-2009 04:23 PM |
| Insinkerator Garbage Disposal | jod2005 | Garbage Disposer Repair | 0 | 12-28-2008 03:34 AM |
| InSinkErator Disposal clogged | djramb2 | Garbage Disposer Repair | 2 | 03-22-2008 07:04 PM |
