Discuss
Tips for installing GE EZ-Mount Disposal.
 in
Garbage Disposer Repair
Whether you are installing or fixing a leaking disposal with GE's EZ mount, there are a few things they don't
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Tips for installing GE EZ-Mount Disposal.
  #1 (permalink)
Old 01-22-2017, 07:59 AM
Junior Member
siepmann is on a distinguished road
Default Tips for installing GE EZ-Mount Disposal.
Brand: GE   Age: 1 - 5 years
Whether you are installing or fixing a leaking disposal with GE's EZ mount, there are a few things they don't tell you that you should know:
1. If replacing the flange WC15X10003, use GE original parts as the ones that you get are not as good as the other ones because even though they have more finishes than GE's plain stainless steel, they don't fit as well.
2. For stainless steel sinks the rubber flange gasket WC03X10007 will work fine but for ceramic sinks because of their irregularities at the drain hole, it needs to be thicker, so use 3 of them.
3. Use the rubber flange gaskets because they hold the flange in place when tightening it up while plumbers putty allows the flange to rotate.
4. While the instructions tell you to tighten the support ring WC05X10002 onto the flange , just loosely screw it on. After attaching the disposal then fully tighten it. This is really important because the disposal's weight will change the positioning of the flange in the sink causing it to probably leak.
5. Put a little vegetable oil on the fiber gasket WC03X10008 that goes between the sink and support ring as it will let you tighten it better and not rotate the flange.
Good Luck.
  #2 (permalink)
Old 05-09-2018, 11:14 PM
Junior Member
fixlogitech is on a distinguished road
Default
great post
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dishwasher won't drain after installing new garbage disposal madden611 Dishwasher Repair 1 11-26-2008 08:30 PM
Tips on installing new dishwasher motor Don73 Dishwasher Repair 3 11-13-2008 11:05 AM
