Appliance Repair Forum
-   Garbage Disposer Repair (http://forum.appliancepartspros.com/garbage-disposer-repair/)
-   -   Monarch Garbage Disposal (http://forum.appliancepartspros.com/garbage-disposer-repair/530951-monarch-garbage-disposal.html)
willie2840 07-20-2013 02:40 PM
I have removed the Monarch garbage disposal but cannot remove the flange that is in the sink it is the type with threads that threads into another flange the 2 parts are rusted together and loose from the sink which means that I have to hold 1 part and try to turn the other part s there a special tool to separate these 2 parts.
scott5495 07-21-2013 11:10 AM
garbage disposal
there is no special wrench for this.
the large nut on the bottom of the sink that holds the flange in, is a flunky metal.
you will have to chisel it to break apart.
willie2840 07-21-2013 12:28 PM
I was able to break it apart from the top using needle nose pliers
it was made out of plastic pretty easy to break.
