Appliance Repair Forum
-   Garbage Disposer Repair (http://forum.appliancepartspros.com/garbage-disposer-repair/)
-   -   low temp in freezer and fridge (http://forum.appliancepartspros.com/garbage-disposer-repair/497866-low-temp-freezer-fridge.html)
chrisv7 08-28-2012 04:44 AM
temp dropped to 50 degrees and freezer dropped to 20 degrees tried to adjust with controls but did nothing what could be the problem.
Simon / APP Team 08-28-2012 03:27 PM
Hi.
Please check if:
-evaporator fan runs
-condenser fan runs
-compressor runs
-evaporator coils blocked with snow
The model number you've posted is incorrect.
Post the results.
Simon.
chrisv7 08-29-2012 08:02 PM
warm fridge and freezer
Compresser was working coils had frost on them but the evaperator fan was not working and the condenser fan was working.
chrisv7 08-29-2012 08:06 PM
Compresser was working coils had frost on them but the evaperator fan was not working and the condenser fan was working. Was going to change evaperator fan but was not sure if I might have a problem with the mother board again.
Simon / APP Team 08-30-2012 10:37 AM
Hi.
The recommendation is to replace both - the mother board and evaporator fan motor.
If you need the part numbers please provide the correct model number of the fridge.
Simon.
