Discuss
removing disposal from sink
 in
Garbage Disposer Repair
there is a clip around collar how do I remove to drop and open to see clog is there a
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » removing disposal from sink
  #1 (permalink)
Old 08-13-2007, 06:44 AM
Carnovallp@hotmail.com Carnovallp@hotmail.com is offline
Junior Member
Carnovallp@hotmail.com is on a distinguished road
Default removing disposal from sink
Brand: Kitchen Aid   Age: 1 - 5 years
is there a special tool
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-13-2007, 01:35 PM
loadster loadster is offline
The Dishwasher Conqueror
loadster will become famous soon enough
Default
Yes there is a tool available at most hardware stores for turning the clamp collar. Before you drop the unit, there is an allen wrech type socket in the disposer shaft at the bottom of the unit. It is near the circuit breaker reset button at the center of the base. I'm not sure but I think it is 3/8 inch. Try manually turning and clearing the obstruction. If you have to drop the unit, and it has any age at all, it would behoove you to purchase a new model as the job is not something you want to do very often. Plus the seals and gaskets are not intended for re-positioning and re-use.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help with Garbage disposal sounds please zuma Garbage Disposer Repair 1 08-11-2007 06:20 PM
Removing rear bearing above brake assembly Scott Washer Repair 2 08-04-2007 10:55 PM
Removing dryer cabinet to repair igniter Mikeofba Dryer Repair 1 07-27-2007 11:48 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
