Discuss
garbage disposal died - won't do anything
 in
Garbage Disposer Repair
I live in an apartment building so i don't know how old the garbage disposal is, but it is a
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » garbage disposal died - won't do anything
  #1 (permalink)
Old 01-31-2012, 06:36 PM
Junior Member
mindiloo is on a distinguished road
Default garbage disposal died - won't do anything
Brand: -brand-   Age: Less than 1 year
I live in an apartment building so i don't know how old the garbage disposal is, but it is a "Badger 1 Insinkerator" and it says "1/3 horsepower" on it.
My roommate and I always run water when using the garbage disposal. I put the tops of my strawberries in the disposal, started running the water, then turned it on. It was going fine then all the sudden it stopped. It made no weird noises, just stopped working as if I had turned it off. I turned it off, felt all round the inside to make sure nothing was stuck just in case, and found nothing but two of the strawberry tops inside so there's nothing jamming it. I left it alone for a little bit and then tried turning it on again but nothing at all happens not even humming.
I'm assuming the motor died, and I don't think I did anything to cause it but I wanted to check before I call my landlord. I'm a bit strapped right now so if I'm going to be charged for the repair I'd rather wait a little before calling.
Any ideas of what happened or things I could try? Any help is appreciated. Thank you!
Ads By Google
  #2 (permalink)
Old 01-31-2012, 06:50 PM
Junior Member
Default
okay I don't see a delete button, but I'll look harder. I kept googling it and I found the reset button soooo problem solved. yay
  #3 (permalink)
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
See if there is a reset button on the bottom that you can push in and then try to run it again.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #4 (permalink)
Old 01-31-2012, 06:51 PM
Junior Member
Default
haha I probably found it just as you posted that, thank you so much for your quick reply!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Garbage Disposal pama59 Garbage Disposer Repair 0 11-27-2011 06:47 AM
Garbage disposal johkar Garbage Disposer Repair 0 10-23-2011 07:01 PM
Garbage disposal cgorman Garbage Disposer Repair 3 07-27-2009 10:35 AM
Garbage disposal Patty65 Garbage Disposer Repair 1 05-11-2009 05:20 PM
Garbage disposal Andrea Higgins Garbage Disposer Repair 0 03-11-2008 11:53 AM
