Discuss
Disposal hums, not jammed, flywheel moves freely.
 in
Garbage Disposer Repair
When my disposal stopped working and produced the hum, I did research and found the solution to get the flywheel
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Disposal hums, not jammed, flywheel moves freely.
  #1 (permalink)
Old 07-09-2009, 07:17 PM
laflizard laflizard is offline
Junior Member
laflizard is on a distinguished road
Question Disposal hums, not jammed, flywheel moves freely.
Model Number: Badger 5   Brand: -other-   Age: 5 - 10 years
When my disposal stopped working and produced the hum, I did research and found the solution to get the flywheel unstuck. It turns out it wasn't stuck; it moved freely in both directions. As I was fiddling around with it I found that I am able to get the disposal running if I get the flywheel going. I insert a long plastic handle into the drain and get the flywheel turning, the motor then takes over and the disposal works fine. I would rather not have to do this whenever I want to use the disposal and was wondering if there is a solution to getting the thing to get started on its own?
Thanks in advance for any ideas.
Related Models
Amana BB20V1E Ref - Bottom Mounts
Amana BB20V1PS Ref - Bottom Mounts
Amana BB20V1S Ref - Bottom Mounts
Amana BB20V1W Ref - Bottom Mounts
Amana BB20VE Ref - Bottom Mounts
Amana BB20VPSE Ref - Bottom Mounts
Amana BB20VSE Ref - Bottom Mounts
Amana BB20VW Ref - Bottom Mounts
Amana BBI20TE Ref - Bottom Mounts
Amana BBI20TL Ref - Bottom Mounts
Amana BBI20TPE Ref - Bottom Mounts
Amana BBI20TPL Ref - Bottom Mounts
Amana BBI20TPSW Ref - Bottom Mounts
Amana BBI20TPW Ref - Bottom Mounts
Amana BBI20TW Ref - Bottom Mounts
Amana BC20B Ref - Bottom Mounts
Amana BC20BA Ref - Bottom Mounts
Amana BC20BC Ref - Bottom Mounts
Amana BC20BG Ref - Bottom Mounts
Amana BC20BL Ref - Bottom Mounts
Amana BC20C Ref - Bottom Mounts
Amana BC20CA Ref - Bottom Mounts
Amana BC20CC Ref - Bottom Mounts
Amana BC20CG Ref - Bottom Mounts
Amana BC20CL Ref - Bottom Mounts
Amana BC20D Ref - Bottom Mounts
Amana BC20DA Ref - Bottom Mounts
Amana BC20DC Ref - Bottom Mounts
Amana BC20DG Ref - Bottom Mounts
Amana BC20DL Ref - Bottom Mounts
Amana BC20E Ref - Bottom Mounts
Amana BC20EA Ref - Bottom Mounts
Amana BC20EC Ref - Bottom Mounts
Amana BC20EG Ref - Bottom Mounts
Amana BC20EL Ref - Bottom Mounts
Amana BC20H Ref - Bottom Mounts
Amana BC20J Ref - Bottom Mounts
Amana BC20K Ref - Bottom Mounts
Amana BC20M Ref - Bottom Mounts
Amana BC20N Ref - Bottom Mounts
Amana BC20TL Ref - Bottom Mounts
Amana BC20TW Ref - Bottom Mounts
Amana BC20W Ref - Bottom Mounts
Amana BC20WA Ref - Bottom Mounts
Amana BC20WAG Ref - Bottom Mounts
Amana BC20WC Ref - Bottom Mounts
Amana BC21V1C Ref - Bottom Mounts
Amana BC21V1W Ref - Bottom Mounts
Amana BC21VC Ref - Bottom Mounts
Amana BC21VL Ref - Bottom Mounts
Amana BC21VW Ref - Bottom Mounts
Frigidaire BCEQ2152ES0 Frigidaire Canada/electric Dryer
Frigidaire BCEQ6100FS0 Frigidaire/dryer
Amana BCI20B Ref - Bottom Mounts
Amana BCI20BA Ref - Bottom Mounts
Amana BCI20BC Ref - Bottom Mounts
Amana BCI20BG Ref - Bottom Mounts
Amana BCI20BL Ref - Bottom Mounts
Amana BCI20C Ref - Bottom Mounts
Amana BCI20CA Ref - Bottom Mounts
Amana BCI20CC Ref - Bottom Mounts
Amana BCI20CG Ref - Bottom Mounts
Amana BCI20CL Ref - Bottom Mounts
Amana BCI20D Ref - Bottom Mounts
Amana BCI20DA Ref - Bottom Mounts
Amana BCI20DC Ref - Bottom Mounts
Amana BCI20DG Ref - Bottom Mounts
Amana BCI20DL Ref - Bottom Mounts
Amana BCI20E Ref - Bottom Mounts
Amana BCI20EA Ref - Bottom Mounts
Amana BCI20EC Ref - Bottom Mounts
Amana BCI20EG Ref - Bottom Mounts
Amana BCI20EL Ref - Bottom Mounts
  #2 (permalink)
Old 09-12-2009, 03:20 PM
ebjerke ebjerke is offline
Junior Member
ebjerke is on a distinguished road
Default I have the same problem
Did you find a solution to this yet? I have the same problem with my disposer right now. I haven't tried the jump start thing that you mentioned, but the flywheel does spin and the motor does hum.
Help, please. I don't like replacing garbage disposals.
  #3 (permalink)
Old 09-15-2009, 03:22 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Your start switch is bad in the disposal, sometimes fixable but you have to remove the disposal.
__________________
  #4 (permalink)
Old 09-15-2009, 10:29 AM
Junior Member
Default
Thanks, but it started working again (for now).
  #5 (permalink)
Old 09-19-2009, 03:09 PM
khelipaul khelipaul is offline
Junior Member
khelipaul is on a distinguished road
Default
Same Problem. My motor is working though.. the humming noise is still there and I have restarted it and used the hex wrench .. there is nothing in the disposal .. the flywheel just isn't turning on its own. help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer drum moves up and down making loud noise azchef Dryer Repair 3 12-15-2008 06:57 PM
New frontload washer moves all over the place on spin cycle alemap68 Washer Repair 0 12-04-2008 05:53 PM
Washer basin moves to right during agitation mcdaniel Washer Repair 1 09-11-2008 09:00 PM
agitator moves very slow carlos p Washer Repair 0 03-31-2008 12:30 AM
Kenmore disposal humms but not jammed sdchism Garbage Disposer Repair 1 12-03-2007 11:07 AM
