Discuss
Garbage Disposer leaks
 in
Garbage Disposer Repair
House is only 20 years old and we bought it this summer - disposer can't be older than 20 yrs -
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Garbage Disposer leaks
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-02-2008, 03:22 PM
papasmurf papasmurf is offline
Junior Member
papasmurf is on a distinguished road
Question Garbage Disposer leaks
Model Number: GFC520F   Brand: GE   Age: More than 10 years
House is only 20 years old and we bought it this summer - disposer can't be older than 20 yrs - but it leaks - I suspect not the flange gasket but the mechanical or shaft seal. Do these get repaired or replaced?
If replaced, should I go ahead and get another GE so I can use the existing flange, etc.?
gracias is advance;
papa smurf
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-03-2008, 11:56 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Your garbage disposer has to be replaced.
As a replacement option I would recommend the 1/2 H.P. continuous feed with quick-lock mounting and galvanized steel grinder garbage disposer made by the Whirlpool.
It has the same design as a very good known In Sink Erator garbage disposer and cost about 25 bucks less.
It comes with the complete, step by step installation instructions.
- The part number for the Whirlpool garbage disposer is AP3121409
Good luck.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 01-06-2008, 06:53 AM
Junior Member
Default Found the problem - between my ears ;-)
It was the flange gasket after all - and it had been incorrectly installed (mind you - a relatively new house) - with both the rubber and fiber gaskets below the sink. A new set of gaskets from a big box store cost $2.15 and after much cussing and torquing I managed to get the thing back in, cleaned up and leak free, tested with both sides of the sink full to the brims for 30 minutes. Thanks to Gene for the reply and also - to the websites for diagrams and instructions on how to uninstall and reinstall the unit.
One other thing - I called GE and purchased parts from them and they are yet to be delivered - the same parts I got for $2.15 from a nearby store cost over $24 from GE mailed tp my house - hopefully I can return them. It is also impossible to understand the customer service reps on the phone - I will not be going that route ever again.
Papa smurf
Good luck.
  #4 (permalink)
Old 01-06-2008, 12:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Disposer died! Leslie Garbage Disposer Repair 7 05-04-2008 08:01 AM
Should I start shopping for a new disposer? clanmcdonough Garbage Disposer Repair 1 12-27-2007 02:46 AM
Disposer won't start barry@barryontheweb.com Garbage Disposer Repair 0 11-08-2007 11:24 AM
Garbage Compactor flaumbetty Trash Compactor Repair 3 10-04-2007 02:02 PM
Help with Garbage disposal sounds please zuma Garbage Disposer Repair 1 08-11-2007 05:20 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
