Discuss
Replace disposal flange
 in
Garbage Disposer Repair
The old rubber stainer dissolved and i tore it out. It seems I must take the disposal off from the
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Replace disposal flange
  #1 (permalink)
Old 12-28-2007, 06:38 PM
redfox redfox is offline
Junior Member
redfox is on a distinguished road
Default Replace disposal flange
Model Number: KCD1250x3   Brand: Kitchen Aid   Age: 1 - 5 years
The old rubber stainer dissolved and i tore it out. It seems I must take the disposal off from the bottom of the sink in order to put in a new rubber "strainer" (is this part called the flange?).
Question: how do i remove the old and install the new rubber sink drain/strain? Where do I buy a new one? This website sells a whirlpool one but i cant tell if it is installed from under the sink or not.
thx
Related Models
General Electric KCD21DAM1 Room air conditioner
Whirlpool KCDB100S0
Whirlpool KCDB150S0
Whirlpool KCDB150S1
Whirlpool KCDB200S0
Whirlpool KCDB250G
Whirlpool KCDB250G1
Whirlpool KCDB250G2 Disposer
Whirlpool KCDB250S0
Whirlpool KCDB250S1
Whirlpool KCDC150G
Whirlpool KCDC150G1
Whirlpool KCDC150K
Whirlpool KCDC150K2 Disposer
Whirlpool KCDC150X
Whirlpool KCDC150X0
Whirlpool KCDC200S0
Whirlpool KCDC250K
Whirlpool KCDC250K2 Disposer
Whirlpool KCDC250S0
Whirlpool KCDC250X
Whirlpool KCDC250X0
Whirlpool KCDC250X1
Whirlpool KCDI250S0
Whirlpool KCDI250S1
Whirlpool KCDI250X
Whirlpool KCDI250X3
Whirlpool KCDS075T0 Disposer
Whirlpool KCDS100T0 Disposer
Whirlpool KCDS250S0
Whirlpool KCDS250S1
Whirlpool KCDS250S2
Whirlpool KCDS250X
Whirlpool KCDS250X1
Whirlpool KCDS250X3
Kelvinator KCG070GW0 Kelvinator/freezer
Kelvinator KCG130GW0 Kelvinator/freezer
Whirlpool KCG200-0 Coffee Mill
Whirlpool KCG200-1 Coffee Mill
Whirlpool KCG200BU0 Coffee Mill
Whirlpool KCG200BU1 Coffee Mill
Whirlpool KCG200BW1 Coffee Mill
Whirlpool KCG200ER0 Coffee Mill
Whirlpool KCG200ER1 Coffee Mill
Whirlpool KCG200GC1 Coffee Mill
Kelvinator KCG200GW0 Kelvinator/freezer
Whirlpool KCG200MC0 Coffee Mill
Whirlpool KCG200MC1 Coffee Mill
Whirlpool KCG200OB0 Coffee Mill
Whirlpool KCG200OB1 Coffee Mill
Whirlpool KCG200PK0 Coffee Mill
Whirlpool KCG200PK1 Coffee Mill
Whirlpool KCG200TG0 Coffee Mill
Whirlpool KCG200TG1 Coffee Mill
Whirlpool KCG200WH0 Coffee Mill
Whirlpool KCG200WH1 Coffee Mill
Whirlpool KCM
General Electric KCM08FAT1 Room air conditioner
General Electric KCM08FAX1 Room air conditioner
General Electric KCM10AAX1 Room air conditioner
General Electric KCM11AAT1 Room air conditioner
General Electric KCM12DAT1 Room air conditioner
General Electric KCM12DAX1 Room air conditioner
General Electric KCM12DBX1 Room air conditioner
Whirlpool KCM511ER0 10 Cup Coffeemaker
Whirlpool KCM511OB0 10 Cup Coffeemaker
Whirlpool KCM511WH0 10 Cup Coffeemaker
Whirlpool KCM514BU0 14 Cup Coffeemaker
Whirlpool KCM514BU1 Coffee Maker, Java Studio I
Whirlpool KCM514ER0 14 Cup Coffeemaker
Whirlpool KCM514ER1 Coffee Maker, Java Studio I
Whirlpool KCM514OB0 14 Cup Coffeemaker
Whirlpool KCM514OB1 Coffee Maker, Java Studio I
Whirlpool KCM514WH0 14 Cup Coffeemaker
Whirlpool KCM514WH1 Coffee Maker, Java Studio I
Whirlpool KCM515ER0 10 Cup Coffeemaker W/thermal Carafe
Whirlpool KCM515OB0 10 Cup Coffeemaker W/thermal Carafe
Whirlpool KCM515WH0 10 Cup Coffeemaker W/thermal Carafe
Whirlpool KCM534ER0 Midline Coffee Maker, Java Studio Ii
Whirlpool KCM534OB0 Midline Coffee Maker, Java Studio Ii
Whirlpool KCM534WH0 Midline Coffee Maker, Java Studio Ii
Whirlpool KCMC155JBL0
Whirlpool KCMC155JBT0
Whirlpool KCMC155JSS0
Whirlpool KCMC155JWH0
Whirlpool KCMG125DBL0
Whirlpool KCMG125DWH0
Whirlpool KCMG125EAL0
Whirlpool KCMG125EBU0
Whirlpool KCMG125ERC0
Whirlpool KCMS122YAL0
Whirlpool KCMS122YBL0
Whirlpool KCMS122YSB0
Whirlpool KCMS122YWH0
Whirlpool KCMS125EBL0
Whirlpool KCMS125EBS0
Whirlpool KCMS125ESB0
Whirlpool KCMS125EWH0
Whirlpool KCMS125YAL0
Whirlpool KCMS125YBL0
Whirlpool KCMS125YSB0
Whirlpool KCMS125YWH0
Whirlpool KCMS132S0
Whirlpool KCMS132S1
Whirlpool KCMS132S2
Whirlpool KCMS132SBL2
Whirlpool KCMS132SBL4
Whirlpool KCMS132SBL5
Whirlpool KCMS132SBL6
Whirlpool KCMS135GBL0
Whirlpool KCMS135GBS0
Whirlpool KCMS135GBT0
Whirlpool KCMS135GSS0
Whirlpool KCMS135GWH0
Whirlpool KCMS135HBL0
Whirlpool KCMS135HBT0
Whirlpool KCMS135HSS0
Whirlpool KCMS135HWH0
Whirlpool KCMS135S0
Whirlpool KCMS135S1
  #2 (permalink)
Old 12-30-2007, 05:28 PM
Admin / APP Team's Avatar
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
I think your model number is KCDI250X3. Click here for breakdown diagrams and parts (by the way, Whirlpool owns KitchenAid, that's why it would say "made by Whirlpool"). Check out the diagram below. I think you're talking about replacing number 8 rubber gasket. If so, the process is quite simple. First, unplug the disposer power cord. Disconnect the drain outlet pipe from the disposer. To remove the garbage disposer insert an allen wrench (there should be one in a pocket taped to the side of the disposer) in to one of the "ears" (See attached photo below) and turn to unlock the disposer from the flange. Now you can replace the rubber gasket. Re-install the disposer and re-connect the drain. Run water through the sink for a minute and make sure there are no leaks.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-30-2008, 02:22 PM
eddieg eddieg is offline
Junior Member
eddieg is on a distinguished road
Default
Had the same problem. Your help made the job quite easy. Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
In sink-erator flange removal RonOh Garbage Disposer Repair 8 09-12-2008 07:55 AM
kenmore 3/4 hp sink disposal sparks eddie2 Garbage Disposer Repair 0 10-12-2007 06:30 PM
Replacing a leaky disposal with a new one glibritz Garbage Disposer Repair 1 10-02-2007 06:02 PM
removing disposal from sink Carnovallp@hotmail.com Garbage Disposer Repair 1 08-13-2007 01:35 PM
Help with Garbage disposal sounds please zuma Garbage Disposer Repair 1 08-11-2007 06:20 PM
