Discuss
Replace disposal flange
 in
Garbage Disposer Repair
The old rubber stainer dissolved and i tore it out. It seems I must take the disposal off from the
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Replace disposal flange
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-28-2007, 05:38 PM
redfox redfox is offline
Junior Member
redfox is on a distinguished road
Default Replace disposal flange
Model Number: KCD1250x3   Brand: Kitchen Aid   Age: 1 - 5 years
The old rubber stainer dissolved and i tore it out. It seems I must take the disposal off from the bottom of the sink in order to put in a new rubber "strainer" (is this part called the flange?).
Question: how do i remove the old and install the new rubber sink drain/strain? Where do I buy a new one? This website sells a whirlpool one but i cant tell if it is installed from under the sink or not.
thx
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-30-2007, 04:28 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
I think your model number is KCDI250X3. Click here for breakdown diagrams and parts (by the way, Whirlpool owns KitchenAid, that's why it would say "made by Whirlpool"). Check out the diagram below. I think you're talking about replacing number 8 rubber gasket. If so, the process is quite simple. First, unplug the disposer power cord. Disconnect the drain outlet pipe from the disposer. To remove the garbage disposer insert an allen wrench (there should be one in a pocket taped to the side of the disposer) in to one of the "ears" (See attached photo below) and turn to unlock the disposer from the flange. Now you can replace the rubber gasket. Re-install the disposer and re-connect the drain. Run water through the sink for a minute and make sure there are no leaks.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-30-2008, 01:22 PM
eddieg eddieg is offline
Junior Member
eddieg is on a distinguished road
Default
Had the same problem. Your help made the job quite easy. Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
In sink-erator flange removal RonOh Garbage Disposer Repair 7 06-09-2008 07:43 PM
kenmore 3/4 hp sink disposal sparks eddie2 Garbage Disposer Repair 0 10-12-2007 05:30 PM
Replacing a leaky disposal with a new one glibritz Garbage Disposer Repair 1 10-02-2007 05:02 PM
removing disposal from sink Carnovallp@hotmail.com Garbage Disposer Repair 1 08-13-2007 12:35 PM
Help with Garbage disposal sounds please zuma Garbage Disposer Repair 1 08-11-2007 05:20 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
