Discuss
Should I start shopping for a new disposer?
 in
Garbage Disposer Repair
Our garrbage disposer has apparently died. It has worked without a hitch since we bought our house (4 years ago -
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Should I start shopping for a new disposer?
  #1 (permalink)
Old 12-26-2007, 08:38 AM
clanmcdonough clanmcdonough is offline
Junior Member
clanmcdonough is on a distinguished road
Default Should I start shopping for a new disposer?
Model Number: 60563   Brand: Kenmore   Age: 5 - 10 years
Our garrbage disposer has apparently died. It has worked without a hitch since we bought our house (4 years ago - the disposer was presumably installed when the house was built - 1997). It did not stop in mid-use, but rather simply will not turn on when the wall switch is flipped (unit is hard-wired into our electrical system). This was not preceded by any unusual noises or jamming. I have checked it for jams (none), I have worked the allen wrench (blades are freely turning), I have checked the circuit breaker (fine), I have pushed the reset button on the bottom of the unit -- all to no avail. Has the engine simply died? Can that happen when the unit is not even turned on?
Thanks in advance for the advice.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-27-2007, 03:46 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
are you sure you still have power coming to the unit ?
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Disposer died! Leslie Garbage Disposer Repair 9 09-24-2008 08:10 PM
Disposer won't start barry@barryontheweb.com Garbage Disposer Repair 0 11-08-2007 12:24 PM
Wont start/start switch replaced awilliams197 Dryer Repair 1 09-18-2007 02:33 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
