Discuss
Disposal won't let dishwasher drain
 in
Garbage Disposer Repair
I don't actually know how old the disposal is, since we just moved into our new home. I'm pretty sure
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Disposal won't let dishwasher drain
  #1 (permalink)
Old 10-01-2011, 11:25 PM
Junior Member
mzumtaylor is on a distinguished road
Default Disposal won't let dishwasher drain
Model Number: GC1000   Brand: Whirlpool   Age: 1 - 5 years
I'm pretty sure that it's the disposal that's causing the problem. I've tried everything else (including two different dishwashers).
We moved in two weeks ago. The first time I ran Dishwasher #1 (Jenn-Air, DW760W), I found standing water in the bottom of the tub when the cycle was complete. I ran through all the normal checks (solenoid/pump working, no kinks/clogs in the drain line, no clogs in the internal workings). I ran the DW on the rinse and hold cycle and on the rinse cycle with the drain hose unhooked from the dishwasher and it drained perfectly.
When I plugged everything back in, I ended up with standing water in the tub again. I thought maybe there was something wrong with the Wash cycle; the only cycle I hadn't tested. I decided that getting a new dishwasher was the solution.
My cousin recently remodeled his kitchen and had a spare dishwasher sitting around. I took it over to our new place and plugged it in. Enter Dishwasher #2 (GE, GSD5500G00CC). Excited that I could now wash all of our dishes after the move, I ran a cycle. I opened it up to find standing water in the basin.
As I was typing up a post to this forum under "dishwasher repair" it occurred to me that I should see if it Dishwasher #2 drained when not plugged into the disposal, which was the only piece I couldn't check because the drain-hose hookup is blocked from visibility by the sink basin. I took a picture with my phone and it didn't look like there was anything blocking the drain input in the disposal, but I couldn't be sure.
In any case, I pulled the drain hose, set it up to drain straight into the sink, and ran a full cycle in Dishwasher #2. Viola, a fully-drained dishwasher.
So now I'm trying to figure out why/how the disposal is blocking the draining of the dishwasher (either of them). I took a second picture of the drain hose hookup and it doesn't look like there's a plug in it (which I know can be a problem). The disposal runs when I flip its switch, and seems to grind up what little food we've put down it (I try not to use my disposal very often).
I've attached a picture of the drain-hose hookup. I'm not sure if the silver circle in the middle is normal, or what.
Help?
Ads By Google
Related Models
Whirlpool GC1000PE DISPOSER
Whirlpool GC1000PE1 DISPOSER
Whirlpool GC1000PE2 DISPOSER
Whirlpool GC1000PE4 DISPOSER
Whirlpool GC1000XE DISPOSER
Whirlpool GC1000XE1 DISPOSER
Whirlpool GC1000XE2 DISPOSER
Whirlpool GC1000XE4 DISPOSER
Frigidaire GC12L
Frigidaire GC15L1
Frigidaire GC18L1
Whirlpool GC1SHAXMB00 REFRIGERATOR
Whirlpool GC1SHAXMQ00 REFRIGERATOR
Whirlpool GC1SHAXMS00 REFRIGERATOR
Whirlpool GC2000PE1 DISPOSER
Whirlpool GC2000PE2 DISPOSER
Whirlpool GC2000PE5 DISPOSER
Whirlpool GC2000XE DISPOSER
Whirlpool GC2000XE1 DISPOSER
Whirlpool GC2000XE2 DISPOSER
Whirlpool GC2000XE5 DISPOSER
Whirlpool GC2000XP DISPOSER
Admiral GC20B7C3EB REF - SXS/I&W
Admiral GC20B7C3EV REF - SXS/I&W
Admiral GC20B8C3EB REF - SXS/I&W
Admiral GC20B8C3EV REF - SXS/I&W
Admiral GC20C7C3EB REF - SXS/I&W
Admiral GC20C7C3EV REF - SXS/I&W
Admiral GC20C8C3EB REF - SXS/I&W
Admiral GC20C8C3EV REF - SXS/I&W
Frigidaire GC20L1
Admiral GC2220DEGB REF - SXS/I&W
Admiral GC2223GEKB REF - SXS/I&W
Admiral GC2223GEKW REF - SXS/I&W
Admiral GC2224GEKB REF - SXS/I&W
Admiral GC2224GEKW REF - SXS/I&W
Admiral GC2225GEK3 REF - SXS/I&W
Admiral GC2225GEK5 REF - SXS/I&W
Admiral GC2225GEK9 REF - SXS/I&W
Admiral GC2225GEKB REF - SXS/I&W
Admiral GC2225GEKS REF - SXS/I&W
Admiral GC2225GEKW REF - SXS/I&W
Admiral GC2225PEKB REF - SXS
Admiral GC2225PEKS REF - SXS
Admiral GC2225PEKW REF - SXS
Admiral GC2227CDFB REF - SXS/I&W
Admiral GC2227CDFW REF - SXS/I&W
Admiral GC2227DEDB REF - SXS/I&W
Admiral GC2227DEDW REF - SXS/I&W
Admiral GC2227EAD3 REF - SXS/I&W
Admiral GC2227EAD5 REF - SXS/I&W
Admiral GC2227EED0 REF - SXS/I&W
Admiral GC2227EED1 REF - SXS/I&W
Admiral GC2227EED3 REF - SXS/I&W
Admiral GC2227EED5 REF - SXS/I&W
Admiral GC2227GEH1 REF - SXS/I&W
Admiral GC2227HEK3 REF - SXS/I&W
Admiral GC2227HEK5 REF - SXS/I&W
Admiral GC2227HEK9 REF - SXS/I&W
Admiral GC2227HEKB REF - SXS/I&W
Admiral GC2227HEKS REF - SXS/I&W
Admiral GC2227HEKW REF - SXS/I&W
Admiral GC2227SDFB REF - SXS/I&W
Admiral GC2227SDFW REF - SXS/I&W
Admiral GC2228EED3 REF - SXS/I&W
Admiral GC2228EED5 REF - SXS/I&W
Admiral GC2228EED9 REF - SXS/I&W
Admiral GC2228EEDB REF - SXS/I&W
Admiral GC2228EEDW REF - SXS/I&W
Admiral GC2228GEH3 REF - SXS/I&W
Admiral GC2228GEH5 REF - SXS/I&W
Admiral GC2228GEH9 REF - SXS/I&W
Admiral GC2228GEHB REF - SXS/I&W
Admiral GC2228GEHW REF - SXS/I&W
Admiral GC2229GEHB REF - SXS/I&W
Admiral GC2229GEHW REF - SXS/I&W
Admiral GC2327PEDB REF - SXS/I&W
Admiral GC2327PEDW REF - SXS/I&W
Admiral GC2328PED3 REF - SXS/I&W
Admiral GC2328PED5 REF - SXS/I&W
Whirlpool GC3000XE DISPOSER
Admiral GC3111SXAW RANGE- F/S STD GAS
Crosley GC3177WUA RANGE- F/S STD GAS
Crosley GC3177WUW RANGE- F/S STD GAS
Admiral GC3211SXAW RANGE-F/S CONT CLEAN GAS
Admiral GC3277WUAM RANGE- F/S STD GAS
Admiral GC3277WUWM RANGE- F/S STD GAS
Admiral GC3277XUAM RANGE- F/S STD GAS
Admiral GC3277XUWM RANGE- F/S STD GAS
Frigidaire GC32BCL0 Frg(v11) / Gas Range
Frigidaire GC32BCL1 Frg(v13) / Gas Range
Frigidaire GC32BCL3 Frg(v2) / Gas Range
Frigidaire GC32BCL4 Frg(v4) / Gas Range
Frigidaire GC32BCW0 Frg(v12) / Gas Range
Frigidaire GC32BCW1 Frg(v14) / Gas Range
Frigidaire GC32BCW3 Frg(v1) / Gas Range
Frigidaire GC32BCW4 Frg(v3) / Gas Range
Frigidaire GC34BCL0 Frg(v13) / Gas Range
Frigidaire GC34BCL1 Frg(v15) / Gas Range
Frigidaire GC34BCL4 Frg(v2) / Gas Range
Frigidaire GC34BCL5 Frg(v4) / Gas Range
Frigidaire GC34BCW0 Frg(v14) / Gas Range
Frigidaire GC34BCW1 Frg(v16) / Gas Range
Frigidaire GC34BCW4 Frg(v1) / Gas Range
Frigidaire GC34BCW5 Frg(v3) / Gas Range
Crosley GC3531WUW RANGE- F/S STD ELE
Whirlpool GC3CHAXNB00 REFRIGERATOR
Whirlpool GC3CHAXNQ00 REFRIGERATOR
Whirlpool GC3CHAXNS00 REFRIGERATOR
Whirlpool GC3CHAXNT00 REFRIGERATOR
Whirlpool GC3JHAXTB00 REFRIGERATOR
Whirlpool GC3JHAXTB01 REFRIGERATOR
Whirlpool GC3JHAXTL00 REFRIGERATOR
Whirlpool GC3JHAXTL01 REFRIGERATOR
Whirlpool GC3JHAXTQ00 REFRIGERATOR
Whirlpool GC3JHAXTQ01 REFRIGERATOR
Whirlpool GC3JHAXTS00 REFRIGERATOR
Whirlpool GC3JHAXTS01 REFRIGERATOR
Whirlpool GC3NHAXSB00 REFRIGERATOR
  #2 (permalink)
Old 10-02-2011, 02:35 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Looks to me like the plug in the disposal is still there.
Here is an install sheet for this type of unit.
https://www.whirlpool.com/digitalass...0W10296116.pdf
__________________
  #3 (permalink)
Old 10-02-2011, 08:09 AM
Junior Member
Default
Thank you for replying to my post so quickly!
Okay, so it sounds like I need to remove my disposal since access to the drain connection is being blocked by the sink. Fortunately, I now have instructions for how to do that.
Thanks again.
  #4 (permalink)
Old 10-21-2011, 08:10 AM
Junior Member
ssssss is on a distinguished road
Default
My disposal just knock plug into disposal & remove
  #5 (permalink)
Old 11-14-2012, 03:35 PM
Junior Member
MkBrennanMD is on a distinguished road
Default
I had the same problem. The dishwasher would run, and at the end of the cycle there was water still inside the machine. I'm not an appliance expert, but I just went through some troubleshooting.
I would take your hoses off and blow through each end to see if there is blockage or not. In my case I took the hose off, and although it looked like it wasn't obstructed, when I blew through it, no air would escape the other end.
The clog was white in color and tough. This stuff builds up over time, almost like someone's artery, and once clogged, your best bet is to throw it out, and get a new hose. Its a cheap solution, and is usually the cause. 30,000 ppl watched my video on dishwasher repair, and a lot of them reported the same issue and solution. My "how to" video on dishwasher repair may help. I used someone else's video when I approached this issue, and the videos helped... Here it is. Goodluck!:
https://www.youtube.com/watch?v=u7uaA2NZKl0
Believe it or not, its not usually food clogging it up, but rather the soaps. Is your machine older than 2 yrs?
__________________
All Appliances I fix, Plus Humans
  #6 (permalink)
Old 11-16-2012, 05:09 PM
Senior Expert
APP Volunteer
Default
MkBrennanMD
I know you are proud of your video and I did watch it and it is pretty good but this is getting a bit much.
It is obvious that the problem here was that the person did not knock out the drain input plug on the garbage disposal.
I my opinion you seem to be flooding the forum with replies that often do not address the poster's problem/symptoms.
A plugged drain tube is not that common usually if a person is using a cycle that heats the water the grease etc. stays in solution. You may have had a sharp kink in the hose that caused your problem. It is much more common for clogs to occur where the drain attaches to the house plumbing. Or if the unit uses a back flow flapper valve at that point. There are many other causes of no draining depending on the make and model.
I do not want to insult you as I know you are just trying to help.
But please stop just adding your post to anything that even mentions a drain problem.
thank you
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to connect disposal drain glenneagleranch@aol.com Dishwasher Repair 0 09-20-2011 02:10 PM
dishwasher food disposal nfoley Dishwasher Repair 1 09-16-2010 09:44 AM
Whirlpool dishwasher backflow from disposal Rick11444 Dishwasher Repair 3 01-16-2010 01:21 AM
Bosch dishwasher won't drain after installing new garbage disposal madden611 Dishwasher Repair 1 11-26-2008 08:30 PM
disposal clogged at dishwasher drain point clecun Garbage Disposer Repair 7 08-26-2008 12:16 PM
