Discuss
sharez:Removing a Garbage Disposal
 in
Garbage Disposer Repair
share the topic and learn some basic Garbage Disposal Removal If you are going to remove and replace the garbage
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » sharez:Removing a Garbage Disposal
  #1 (permalink)
Old 07-02-2011, 01:27 AM
Junior Member
billlikecar is on a distinguished road
Default sharez:Removing a Garbage Disposal
Model Number: 01   Brand: -brand-   Age: Less than 1 year
If you are going to remove and replace the garbage disposal with the same type of unit the removal process will not involve removing the mounting assembly.
To remove the garbage disposal proceed as follows:
  • Turn off power to the disposal at the electrical service panel.
  • If you have a dishwasher attached to the disposal, use a screwdriver to loosen the hose clamp attaching the dishwasher hose to the barbed dishwasher nipple and remove the hose.
  • Next, remove the "P" trap waste line. Place a bucket under the "P" trap to catch the waste water and using an adjustable wrench or large mouth tongue and groove pliers, loosen and unscrew the slip-nut that connects the waste pipe from the disposal's discharge tube.
  • If the slip nuts are frozen in place or you cannot separate the pipe, then cut it with a hacksaw in the straight section of the waste pipe.
  • Next, remove the disposal from the disposal mounting assembly ring ring by placing a screwdriver in one of the disposal's mounting ring lugs that attach to the lower mounting ring. Turn to the left (counter-clockwise) until the mounting ring is separated from the disposal and remove the unit from the mounting flange.
Ads By Google
Related Models
Hoover 021 Frigidaire/refrigerator
Hoover 0510
Hoover 0513
Hoover 0515
Hoover 0517-10
Hoover 0517-20
Hoover 0517-30
Hoover 0519
Hoover 0519-10
Hoover 0519-30
Hoover 0519-60 Frigidaire/electric Range
Hoover 0519-70 Frigidaire/electric Range
Hoover 0519-80
Hoover 0610 Frigidaire/freezer
Hoover 0611 White Westinghouse/refrigerator
Hoover 0612 Frigidaire/walloven
Hoover 0613 Frigidaire/freezer
Hoover 0617
Hoover 0617-61 Frigidaire/walloven
Hoover 0617-64 Frigidaire/walloven
Hoover 0620 Frigidaire/walloven
Hoover 0622 Frigidaire/walloven
Hoover 0630 Frigidaire/walloven
Hoover 0632
Hoover 0710 Frigidaire/freezer
Hoover 0750
Whirlpool 0773B10
Whirlpool 0783B10
Hoover 0810
Hoover 0811 Frigidaire/freezer
Hoover 0914 Frigidaire/freezer
Hoover 0914-61 Frigidaire/refrigerator
Hoover 0914-64
Hoover 0916 White Westinghouse/refrigerator
Hoover 0916T
Hoover 0916T-01
Hoover 0920
Admiral 1
Amana 10-2NM Room Air Conditioner
Whirlpool 1005000
Whirlpool 1005200
Whirlpool 1005300
Whirlpool 1005400
Whirlpool 1005500
Amana 1008.000 Mwave - Family Size (60 Hz)
Amana 1009.000 Mwave - Family Size (60 Hz)
Amana 100A-20 Room Air Conditioner
Amana 100A-2M Room Air Conditioner
Amana 100A-2N Room Air Conditioner
Amana 100A-30 Room Air Conditioner
Amana 100A-30H Room Air Conditioner
Amana 100A-356 Room Air Conditioner
Amana 100A-3A Room Air Conditioner
Amana 100A-3HN Room Air Conditioner
Amana 100A-3M Room Air Conditioner
Amana 100A-3N Room Air Conditioner
Amana 100A-3P Room Air Conditioner
Amana 100A-3PH Room Air Conditioner
Amana 100A-3R Room Air Conditioner
Amana 100A-3RH Room Air Conditioner
Amana 100A-556 Room Air Conditioner
Amana 100A-8R Room Air Conditioner
Amana 100B-3A Room Air Conditioner
Amana 100C-20
Amana 100C-20H
Amana 100C-2N Room Air Conditioner
Amana 100C-2N1 Room Air Conditioner
Amana 100C-2P Room Air Conditioner
Amana 100C-2PH Room Air Conditioner
Amana 100C-2R Room Air Conditioner
Amana 100C-2RH Room Air Conditioner
Amana 100C-2RHL Room Air Conditioner
Amana 100C-2RL Room Air Conditioner
Amana 100C-30
Amana 100C-30H
Amana 100C-3N Room Air Conditioner
Amana 100C-3N1 Room Air Conditioner
Amana 100C-3P Room Air Conditioner
Amana 100C-3PH Room Air Conditioner
Amana 100C-3R Room Air Conditioner
Amana 100C-3RH Room Air Conditioner
Amana 100C-3RHL Room Air Conditioner
Amana 100C-3RL Room Air Conditioner
Amana 100C-8P Room Air Conditioner
Amana 100C-8R Room Air Conditioner
Amana 100C-8RH Room Air Conditioner
Amana 100C-8RHL Room Air Conditioner
Amana 100C-8RL Room Air Conditioner
Amana 100D-2HM
Amana 100D-2M
Amana 100D-2MA
Amana 100D-2MB
Amana 100D-356 Room Air Conditioner
Amana 100D-3M
Amana 100D-556 Room Air Conditioner
Amana 100LA-20 Room Air Conditioner
Amana 100LA-2N Room Air Conditioner
Amana 100LC-20
Amana 100LC-2N Room Air Conditioner
Amana 100LC-2P Room Air Conditioner
Amana 100LC-2R Room Air Conditioner
Amana 100LC-2RH Room Air Conditioner
Amana 100LCS-20
Amana 100LCS-2N Room Air Conditioner
Amana 100LCS-2P Room Air Conditioner
Hoover 1010
Amana 1010.000 Mwave - Family Size (60 Hz)
Amana 1011.000 Mwave - Family Size (60 Hz)
Amana 1015.000 Mwave - Family Size (60 Hz)
Amana 1018.000 Mwave - Family Size (60 Hz)
Amana 102.000 Mwave - Family Size (60 Hz)
Amana 102.001 Mwave - Family Size (60 Hz)
Amana 102.002 Mwave - Family Size (60 Hz)
Hoover 1020
Amana 1020.0 Mwave - Family Size (60 Hz)
Amana 1020.000 Mwave - Family Size (60 Hz)
Amana 1021.000 Mwave - Family Size (60 Hz)
Whirlpool 1021B16
Whirlpool 1021B26
Whirlpool 1021B36
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Removing Garbage disposal R. Rusciano Garbage Disposer Repair 0 08-15-2010 01:51 PM
Garbage Disposal Linda French Garbage Disposer Repair 1 11-01-2009 06:20 AM
Garbage disposal cgorman Garbage Disposer Repair 3 07-27-2009 10:35 AM
GE Garbage Disposal Jim Toy Garbage Disposer Repair 0 04-18-2009 01:12 PM
GE garbage disposal Mikark Garbage Disposer Repair 1 01-06-2009 10:57 AM
