Discuss
InSink Erator Hums, Blades Turn, Doesn't Work
 in
Garbage Disposer Repair
My InSink Erator will not work and only hums. It drains very very slow. I can turn the blades using
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » InSink Erator Hums, Blades Turn, Doesn't Work
  #1 (permalink)
Old 03-03-2009, 06:11 PM
chinahorse chinahorse is offline
Junior Member
chinahorse is on a distinguished road
Default InSink Erator Hums, Blades Turn, Doesn't Work
Brand: -other-   Age: More than 10 years
I can turn the blades using the special tool inserted in the bottom. It turns easily in either direction. The reset button does not help.
I also tried using Drano just for kicks, but that didn't help.
I am thinking the only thing left is to replace the unit, but I don't understand why it would still just hum if the blades are turning ok.
Anything else I can try or is it time for a new one?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How do I replace In-Sink-erator 777 Gasket AtlDick Garbage Disposer Repair 1 12-03-2008 12:18 PM
In sink-erator flange removal RonOh Garbage Disposer Repair 8 09-12-2008 07:55 AM
motor hums but drum will not turn judy71635@alltel.net Dryer Repair 1 07-30-2008 09:28 PM
My Mircowave HUMS when I turn in on. CAR417 Microwave Repair 2 05-06-2008 10:51 PM
Dryer motor hums & will not turn mmaynard Dryer Repair 1 01-29-2008 12:53 PM
