Discuss
GFCI pops intermittently
 in
Garbage Disposer Repair
my 2.5 yr old garbage disposal started popping the gfci. I can hear the motor start and immediately spins
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » GFCI pops intermittently
  #1 (permalink)
Old 02-11-2009, 10:16 AM
gtnrfn gtnrfn is offline
Junior Member
gtnrfn is on a distinguished road
Default GFCI pops intermittently
Model Number: 175.60572   Brand: Kenmore   Age: 1 - 5 years
my 2.5 yr old garbage disposal started popping the gfci. I can hear the motor start and immediately spins to a stop. I have tried another gfci and it pops also. I connected to a non gfci circuit and motor runs ok. disposal is clear and free. what could be the problem? thanks!
Related Models
Amana 1750.000 Mwave - Family Size (60 Hz)
Amana 1752.000 Mwave - Family Size (60 Hz)
Amana 1752.001 Mwave - Family Size (60 Hz)
Whirlpool 1765W0A
Whirlpool 1765^0A
Amana 1780.000 Mwave - Family Size (60 Hz)
Amana 18 Freezer - Vertical
Whirlpool 1821W06
Whirlpool 1821^06
Whirlpool 1833W0A
Whirlpool 1833^0A
Whirlpool 1835W0A
Whirlpool 1835W1A
Whirlpool 1835W2A
Whirlpool 1835^0A
Whirlpool 1835^1A
Whirlpool 1835^2A
Whirlpool 1835^3A
Whirlpool 1838W46
Whirlpool 1838W56
Whirlpool 1838W66
Whirlpool 1838^46
Whirlpool 1838^56
Whirlpool 1838^66
Amana 1870.000 Mwave - Family Size (60 Hz)
Whirlpool 1872W0A
Whirlpool 1872W1A
Whirlpool 1873W0A
Whirlpool 1873W1A
Whirlpool 1873^0A
Whirlpool 1873^1A
Whirlpool 1878W26
Whirlpool 1878W36
Whirlpool 1878W46
Whirlpool 1878^26
Whirlpool 1878^36
Whirlpool 1878^46
Amana 1880.000 Mwave - Family Size (60 Hz)
Whirlpool 1883W0A
Whirlpool 1883^0A
Whirlpool 1885W0A
Whirlpool 1885W1A
Whirlpool 1885W3A
Whirlpool 1885^0A
Whirlpool 1885^1A
Whirlpool 1885^3A
Whirlpool 1889W06
Whirlpool 1889W16
Whirlpool 1889W46
Whirlpool 1889W56
Whirlpool 1889W66
Whirlpool 1889^06
Whirlpool 1889^16
Whirlpool 1889^46
Whirlpool 1889^56
Whirlpool 1889^66
Amana 1890.000 Mwave - Family Size (60 Hz)
Whirlpool 1893W0A
Whirlpool 1893^0A
Whirlpool 1895W0A
Whirlpool 1895^0A
Amana 18A Freezer - Vertical
Amana 18B Freezer - Vertical
Amana 18B1 Freezer - Vertical
Amana 18B2 Freezer - Vertical
Amana 18C Freezer - Vertical
Amana 18C3EV Room Air Conditioner
Amana 18C3EW Room Air Conditioner
Amana 18C3HES Room Air Conditioner
Amana 18C3HEV Room Air Conditioner
Amana 18C3HEW Room Air Conditioner
Amana 18C3MA Room Air Conditioner
Amana 18C3MD Room Air Conditioner
Amana 18C3MY Room Air Conditioner
Amana 18C3SA Room Air Conditioner
Amana 18C3Y Room Air Conditioner
Amana 18C5EV Room Air Conditioner
Amana 18C5EY Room Air Conditioner
Amana 18C5V Room Air Conditioner
Amana 18C5W Room Air Conditioner
Amana 18C5Y Room Air Conditioner
Frigidaire 18HA181
Frigidaire 18HA181A
Amana 18M23TA Room Air Conditioner
Amana 18M23TB Room Air Conditioner
Amana 18M33PAE Room Air Conditioner
Amana 18M33PAEH Room Air Conditioner
Amana 18M33PBE Room Air Conditioner
Amana 18M33PBEH Room Air Conditioner
Amana 18M33PCE Room Air Conditioner
Amana 18M33PCEH Room Air Conditioner
Amana 18M53TA Room Air Conditioner
Amana 18M53TB Room Air Conditioner
Amana 18QZ33RC Room Air Conditioner
Amana 18QZ33RC1 Room Air Conditioner
Amana 18QZ33TA Room Air Conditioner
Amana 18QZ33TB Room Air Conditioner
Magic Chef 18RA-3B Rv Range - Gas
Magic Chef 18RA-3BTZ Rv Range - Gas
Magic Chef 18RA-4 Rv Range - Gas
Magic Chef 18RA-4TZ Rv Range - Gas
Magic Chef 18RA-4Z Rv Range - Gas
Magic Chef 18RB-4 Rv Range - Gas
Magic Chef 18RB-4TZ Rv Range - Gas
Magic Chef 18RB-4Z Rv Range - Gas
Magic Chef 18RS-4 Rv Range - Gas
Magic Chef 18RS-4TZ Rv Range - Gas
Magic Chef 18RS-4Z Rv Range - Gas
Magic Chef 18RW-3B Rv Range - Gas
Magic Chef 18RW-3BTZ Rv Range - Gas
  #2 (permalink)
Old 02-14-2009, 08:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
GFCI stands for "Ground Fault Circuit Interrupter." This is a safety device to prevent users from electrocution by sensing any small current leaking to ground which a regular circuit breaker is not able to sense. It's hard to say if it's safe to use the garbage disposal without proper diagnosis performed by a certified electrician.
__________________
  #3 (permalink)
Old 02-15-2009, 07:11 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Cannot find any info on the Model Number
Your problem is probably in the motor.
As motors age they can become electrically noisy re: arcing.
This often can cause GFI problems.
If the motor uses brushes just the dust from the brushes can cause GFI problems.
If any moisture gets into the motor that will also cause a GFI to trip
Use of a GFI on a disposal is probably regulated by your local electrical code.
Personally I think it is probably a good idea especially if your sink is floating (not grounded)
In the old days all sinks were grounded. Earth ground was connected to the water pipes coming into the house, all the plumbing was copper and all the taps were metal so the sinks were grounded
These days with the use of plastic pipes, non metal sink hook ups and non metal taps often the sink is not grounded.
So if you should loose neutral and the garbage disposal/sink goes live and you touch the sink and any grounded device (stove etc.) you would get a shock.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Oven trips the GFCI breaker. merhein Oven Repair (including Ranges and Cooktops) 10 04-06-2009 04:32 PM
Freezer Door Pops Open CalifTom Refrigerator & Freezer Repair 5 11-23-2008 07:15 PM
Whirlpool Washer Trips GFCI bjthedj Washer Repair 7 11-19-2008 01:03 PM
Oven door pops open richardt Oven Repair (including Ranges and Cooktops) 3 10-20-2008 08:11 PM
Whole fridge and freezer unit pops breaker manu Refrigerator & Freezer Repair 4 09-16-2007 08:15 AM
