Discuss
Flange not flush. GD wont work.
 in
Garbage Disposer Repair
GD has power, hums. Used hex and reset button. all moves freely but the flange? moves side to side and
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Flange not flush. GD wont work.
  #1 (permalink)
Old 02-01-2009, 04:18 AM
hobie0777@msn.com hobie0777@msn.com is offline
Junior Member
hobie0777@msn.com is on a distinguished road
Default Flange not flush. GD wont work.
Brand: Sears   Age: 5 - 10 years
GD has power, hums. Used hex and reset button. all moves freely but the flange? moves side to side and doesn't stay flush. Impellers, not sure of their name but the little grinders move freely. Is the flange supposed to stay securely flush in the GD? It almost seems as if it isnt tight to the main shaft? Problem was originally GD would hum but wouldnt grind food. I have check all clogs, used wrench, reset button but noticed flange moves side to side at an awkward position. Do not know if that is normal. Any help or is it doomed to GD heaven? Thanks, Sally
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
clothes dryer wont heat timer wont work tampee Dryer Repair 2 01-17-2009 10:53 AM
Flange snap ring not holding, specialty flange wranglerbrat Garbage Disposer Repair 0 11-27-2008 11:57 AM
Oven isnt flush to the wall stove help Oven Repair (including Ranges and Cooktops) 1 09-08-2008 03:39 PM
Replace disposal flange redfox Garbage Disposer Repair 2 03-30-2008 02:22 PM
My Washer Doesn't Flush Out The Water Oscar10 Washer Repair 1 02-20-2008 02:24 PM
