Discuss
Trash Compactor not turning on
 in
Garbage Disposer Repair
i just moved into this home a month and a half ago. I don't know anything about trash compactors
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Trash Compactor not turning on
  #1 (permalink)
Old 10-30-2007, 01:40 PM
RafiJ RafiJ is offline
Junior Member
RafiJ is on a distinguished road
Exclamation Trash Compactor not turning on
Brand: -brand-   Age: 1 - 5 years
i just moved into this home a month and a half ago. I don't know anything about trash compactors apart from the fact that, one can put solid foods in and turn the switch on. It takes in every kind of food i've put in (spinach, cottage cheese, chicken (bones), etc). Two days ago I turned it on and it would not start. There is a light switch right beside the compactor switch. I turned the light switch on and the light came on, but the compactor switch does not seem to be reacting at all. It's also clogged the drain. When the sink is turned on the water does not go down. Please help me and tell me what I should be doing to fix this problem and I am completely lost. Thanks!
  #2 (permalink)
Old 10-31-2007, 01:38 AM
Admin / APP Team's Avatar
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Well, sounds like you're talking about the garbage disposer. Try this:
1. Make sure the disposer power cord is plugged in and the wall socket has power with the switch on (try plugging something else in the socket to test or use a voltmeter).
2. Press the red reset button at the bottom of the disposer and try it again.
3. If the disposer is jammed, read this post on how to release it.
Here is a sample Use and Care manual for a Whirlpool garbage disposer. It will tell you how to use the disposer, what you can put in it, etc.
Post the results here.
  #3 (permalink)
Old 11-21-2007, 09:24 AM
Junior Member
Default Thank you!!!
thank you!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
lower arm not turning Philip Wolke Dishwasher Repair 2 01-27-2008 11:22 AM
jenn air trash compactor sticks rbern007 Trash Compactor Repair 3 10-11-2007 11:34 PM
Whirlpool Trash Compactor --Model #TC900QPDQ1 trout Trash Compactor Repair 1 10-11-2007 11:22 PM
Trash compactor Centrifugal switch msehome Trash Compactor Repair 0 10-02-2007 06:44 AM
Trash Compactor MValley General Talk 1 08-17-2007 09:25 AM
