Discuss
Garbage Disposer Problem
 in
Garbage Disposer Repair
The Insinkerator Badger 1 had a small spoon go in it. The head of the spoon was removed but the
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Garbage Disposer Problem
  #1 (permalink)
Old 01-01-2009, 03:05 PM
Philip Milligan Philip Milligan is offline
Junior Member
Philip Milligan is on a distinguished road
Red face Garbage Disposer Problem
Model Number: Badger 1   Brand: -other-   Age: 5 - 10 years
The Insinkerator Badger 1 had a small spoon go in it. The head of the spoon was removed but the handle is jammed inside. The z tool can't turn the insides at all. Any suggestions ?
I took the unit apart and removed the rest of the spoon.The reassemble instruction that says to " hang disposer by aligning 3 mounting tabs w/slide up ramps on mounting ring" does/nt seem to go together as easy as they make it sound. Any suggestions?
Related Models
Amana BB20V1E Ref - Bottom Mounts
Amana BB20V1PS Ref - Bottom Mounts
Amana BB20V1S Ref - Bottom Mounts
Amana BB20V1W Ref - Bottom Mounts
Amana BB20VE Ref - Bottom Mounts
Amana BB20VPSE Ref - Bottom Mounts
Amana BB20VSE Ref - Bottom Mounts
Amana BB20VW Ref - Bottom Mounts
Amana BBI20TE Ref - Bottom Mounts
Amana BBI20TL Ref - Bottom Mounts
Amana BBI20TPE Ref - Bottom Mounts
Amana BBI20TPL Ref - Bottom Mounts
Amana BBI20TPSW Ref - Bottom Mounts
Amana BBI20TPW Ref - Bottom Mounts
Amana BBI20TW Ref - Bottom Mounts
Amana BC20B Ref - Bottom Mounts
Amana BC20BA Ref - Bottom Mounts
Amana BC20BC Ref - Bottom Mounts
Amana BC20BG Ref - Bottom Mounts
Amana BC20BL Ref - Bottom Mounts
Amana BC20C Ref - Bottom Mounts
Amana BC20CA Ref - Bottom Mounts
Amana BC20CC Ref - Bottom Mounts
Amana BC20CG Ref - Bottom Mounts
Amana BC20CL Ref - Bottom Mounts
Amana BC20D Ref - Bottom Mounts
Amana BC20DA Ref - Bottom Mounts
Amana BC20DC Ref - Bottom Mounts
Amana BC20DG Ref - Bottom Mounts
Amana BC20DL Ref - Bottom Mounts
Amana BC20E Ref - Bottom Mounts
Amana BC20EA Ref - Bottom Mounts
Amana BC20EC Ref - Bottom Mounts
Amana BC20EG Ref - Bottom Mounts
Amana BC20EL Ref - Bottom Mounts
Amana BC20H Ref - Bottom Mounts
Amana BC20J Ref - Bottom Mounts
Amana BC20K Ref - Bottom Mounts
Amana BC20M Ref - Bottom Mounts
Amana BC20N Ref - Bottom Mounts
Amana BC20TL Ref - Bottom Mounts
Amana BC20TW Ref - Bottom Mounts
Amana BC20W Ref - Bottom Mounts
Amana BC20WA Ref - Bottom Mounts
Amana BC20WAG Ref - Bottom Mounts
Amana BC20WC Ref - Bottom Mounts
Amana BC21V1C Ref - Bottom Mounts
Amana BC21V1W Ref - Bottom Mounts
Amana BC21VC Ref - Bottom Mounts
Amana BC21VL Ref - Bottom Mounts
Amana BC21VW Ref - Bottom Mounts
Frigidaire BCEQ2152ES0 Frigidaire Canada/electric Dryer
Frigidaire BCEQ6100FS0 Frigidaire/dryer
Amana BCI20B Ref - Bottom Mounts
Amana BCI20BA Ref - Bottom Mounts
Amana BCI20BC Ref - Bottom Mounts
Amana BCI20BG Ref - Bottom Mounts
Amana BCI20BL Ref - Bottom Mounts
Amana BCI20C Ref - Bottom Mounts
Amana BCI20CA Ref - Bottom Mounts
Amana BCI20CC Ref - Bottom Mounts
Amana BCI20CG Ref - Bottom Mounts
Amana BCI20CL Ref - Bottom Mounts
Amana BCI20D Ref - Bottom Mounts
Amana BCI20DA Ref - Bottom Mounts
Amana BCI20DC Ref - Bottom Mounts
Amana BCI20DG Ref - Bottom Mounts
Amana BCI20DL Ref - Bottom Mounts
Amana BCI20E Ref - Bottom Mounts
Amana BCI20EA Ref - Bottom Mounts
Amana BCI20EC Ref - Bottom Mounts
Amana BCI20EG Ref - Bottom Mounts
Amana BCI20EL Ref - Bottom Mounts
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Garbage Disposer MILLERHOME Garbage Disposer Repair 1 12-22-2008 03:58 PM
Garbage Disposer Clifton Addison Garbage Disposer Repair 2 09-06-2008 12:50 PM
Garbage Disposer Clifton Addison Garbage Disposer Repair 1 08-29-2008 10:44 AM
Garbage disposer bstoffel Garbage Disposer Repair 1 07-22-2008 11:51 PM
Garbage Disposer leaks papasmurf Garbage Disposer Repair 3 01-06-2008 01:18 PM
