Discuss
Garbage Disposer Turn Off
 in
Garbage Disposer Repair
Unplugged the disposer to do a water filter change but when plugging back in, the disposer started up and will
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Garbage Disposer Turn Off
  #1 (permalink)
Old 02-14-2011, 05:52 AM
Junior Member
baldridge is on a distinguished road
Default Garbage Disposer Turn Off
Model Number: Custom 250   Brand: Kitchen Aid   Age: 1 - 5 years
Unplugged the disposer to do a water filter change but when plugging back in, the disposer started up and will not stop running. Never touched the wall switch. How do I spot it? The reset button doesn't seem to change anything.
Ads By Google
Related Models
Thermador CV136
Thermador CV2136
Thermador CV2136-01
Thermador CV2230
Thermador CV2230N
Thermador CV2236
Thermador CV2236N
Whirlpool CVAC062XL0
Amana CVC3000E Hood
Jenn-Air CVDX4180B Surface Unit - Ddraft Gas
Jenn-Air CVDX4180W Surface Unit - Ddraft Gas
Jenn-Air CVE1400B Surface Unit - Ddraft Ele
Jenn-Air CVE1400B-C Surface Unit - Ddraft Ele
Jenn-Air CVE1400W Surface Unit - Ddraft Ele
Jenn-Air CVE1400W-C Surface Unit - Ddraft Ele
Jenn-Air CVE3400B Surface Unit - Ddraft Ele
Jenn-Air CVE3400W Surface Unit - Ddraft Ele
Jenn-Air CVE3401B Surface Unit - Ddraft Ele
Jenn-Air CVE3401Q Surface Unit - Ddraft Ele
Jenn-Air CVE3401W Surface Unit - Ddraft Ele
Jenn-Air CVE407B Surface Unit - Ddraft Ele
Jenn-Air CVE407B-C Surface Unit - Ddraft Ele
Jenn-Air CVE407W Surface Unit - Ddraft Ele
Jenn-Air CVE407W-C Surface Unit - Ddraft Ele
Jenn-Air CVE4180B Surface Unit - Ddraft Ele
Jenn-Air CVE4180B-C Surface Unit - Ddraft Ele
Jenn-Air CVE4180S Surface Unit - Ddraft Ele
Jenn-Air CVE4180S-C Surface Unit - Ddraft Ele
Jenn-Air CVE4180W Surface Unit - Ddraft Ele
Jenn-Air CVE4180W-C Surface Unit - Ddraft Ele
Jenn-Air CVE4270B Surface Unit - Ddraft Ele
Jenn-Air CVE4270B-C Surface Unit - Ddraft Ele
Jenn-Air CVE4270S Surface Unit - Ddraft Ele
Jenn-Air CVE4270S-C Surface Unit - Ddraft Ele
Jenn-Air CVE4270W Surface Unit - Ddraft Ele
Jenn-Air CVE4270W-C Surface Unit - Ddraft Ele
Jenn-Air CVE4370B Surface Unit - Ddraft Ele
Jenn-Air CVE4370W Surface Unit - Ddraft Ele
Jenn-Air CVEX4100B Surface Unit - Ddraft Ele
Jenn-Air CVEX4100W Surface Unit - Ddraft Ele
Jenn-Air CVEX4270B Surface Unit - Ddraft Ele
Jenn-Air CVEX4270W Surface Unit - Ddraft Ele
Jenn-Air CVEX4370B Surface Unit - Ddraft Ele
Jenn-Air CVEX4370W Surface Unit - Ddraft Ele
Jenn-Air CVG2420B Surface Base Unit - Ddraft Gas
Jenn-Air CVG2420W Surface Base Unit - Ddraft Gas
Jenn-Air CVG316B Surface Unit - Ddraft Gas
Jenn-Air CVG316W Surface Unit - Ddraft Gas
Jenn-Air CVG4100B Surface Unit - Ddraft Gas
Jenn-Air CVG4280B Surface Unit - Ddraft Gas
Jenn-Air CVG4280S Surface Unit - Ddraft Gas
Jenn-Air CVG4280W Surface Unit - Ddraft Gas
Jenn-Air CVG4380B Surface Unit - Ddraft Gas
Jenn-Air CVG4380P Surface Unit - Ddraft Gas
Jenn-Air CVG4380PD Surface Unit - Ddraft Gas
Jenn-Air CVG4380PF Surface Unit - Ddraft Gas
Jenn-Air CVG4380PG Surface Unit - Ddraft Gas
Jenn-Air CVG4380PK Surface Unit - Ddraft Gas
Jenn-Air CVG4380PR Surface Unit - Ddraft Gas
Jenn-Air CVG4380PU Surface Unit - Ddraft Gas
Jenn-Air CVG4380W Surface Unit - Ddraft Gas
Jenn-Air CVGX2423B Surface Base Unit - Ddraft Gas
Jenn-Air CVGX2423Q Surface Base Unit - Ddraft Gas
Jenn-Air CVGX2423W Surface Base Unit - Ddraft Gas
Whirlpool CVR1000
Whirlpool CVR2000
Whirlpool CVR3000
Whirlpool CVR500
Whirlpool CVR600
Whirlpool CVR6001
Thermador CVS30RB
Thermador CVS30RS
Thermador CVS30RW
Thermador CVS36RB
Thermador CVS36RS
Thermador CVS36RW
Thermador CVS45RB
Thermador CVS45RS
Thermador CVS45RW
Thermador CVSE36B
Crosley CW18C1 Washer - Top Loading
Crosley CW18C100 Washer - Top Loading
Crosley CW18C124 Washer - Top Loading
Crosley CW18C125 Washer - Top Loading
Crosley CW18C126 Washer - Top Loading
Crosley CW18C127 Washer - Top Loading
Crosley CW18C1A Washer - Top Loading
Crosley CW18C1H Washer - Top Loading
Crosley CW18C3A Washer - Top Loading
Crosley CW18C3H Washer - Top Loading
Crosley CW18C3W Washer - Top Loading
Crosley CW18M4 Washer - Top Loading
Crosley CW18M4A Washer - Top Loading
Crosley CW18M4H Washer - Top Loading
Crosley CW18M4W Washer - Top Loading
Crosley CW18P2A Washer - Top Loading
Crosley CW18P2AC Washer - Top Loading
Crosley CW18P2H Washer - Top Loading
Crosley CW18P2HC Washer - Top Loading
Crosley CW18P2W Washer - Top Loading
Crosley CW18P2WC Washer - Top Loading
Crosley CW18P6A Washer - Top Loading
Crosley CW18P6H Washer - Top Loading
Crosley CW18P6W Washer - Top Loading
Crosley CW18T2A Washer - Top Loading
Crosley CW18T2W Washer - Top Loading
Crosley CW20C5A Washer - Top Loading
Crosley CW20C5H Washer - Top Loading
Crosley CW20C5W Washer - Top Loading
Crosley CW20C7A Washer - Top Loading
Crosley CW20C7W Washer - Top Loading
Crosley CW20M4A Washer - Top Loading
Crosley CW20M6 Washer - Top Loading
Crosley CW20M6A Washer - Top Loading
Crosley CW20M8 Washer - Top Loading
Crosley CW20M8A Washer - Top Loading
Crosley CW20M8H Washer - Top Loading
Crosley CW20M9A Washer - Top Loading
Crosley CW20M9N Washer - Top Loading
Crosley CW20P4A Washer - Top Loading
  #2 (permalink)
Old 02-16-2011, 09:24 PM
Admin / APP Team's Avatar
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
You've probably checked this already, but did you plug it back in the right socket? Usually, you would have a double socket under the sink where one socket is controlled by the on/off switch (for the disposer) and the other is always on.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 02-17-2011, 01:03 PM
Junior Member
Default
Quote:
Originally Posted by baldridge View Post
Unplugged the disposer to do a water filter change but when plugging back in, the disposer started up and will not stop running. Never touched the wall switch. How do I stop it? The reset button doesn't seem to change anything.
I did exactly as you suggested, plugged it back in the socket that is always on. I didn't know that is how the under the sink duplex is set up. Thanks for your response.
  #4 (permalink)
Old 02-17-2011, 01:23 PM
Administrator
APP Team
Default
Awesome. Glad to hear you got it solved.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
garbage disposer ish2008 Dishwasher Repair 3 10-15-2010 07:04 AM
Ge Garbage Disposer MILLERHOME Garbage Disposer Repair 1 12-22-2008 02:58 PM
Garbage Disposer Clifton Addison Garbage Disposer Repair 2 09-06-2008 11:50 AM
Garbage Disposer Clifton Addison Garbage Disposer Repair 1 08-29-2008 09:44 AM
Garbage disposer bstoffel Garbage Disposer Repair 1 07-22-2008 10:51 PM
