Discuss
Disposer died!
 in
Garbage Disposer Repair
Was using the disposer and it stopped, I thought something had jammed it. I turned it off to check it
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Disposer died!
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-08-2007, 04:52 PM
Leslie Leslie is offline
Junior Member
Leslie is on a distinguished road
Default Disposer died!
Model Number: 72345(?)   Brand: Kenmore   Age: 1 - 5 years
Was using the disposer and it stopped, I thought something had jammed it. I turned it off to check it and there wasn't anything in it that i could see. Now when we turn it on it hums and sometimes doesn't even do that. I'm not having any dishwasher/sink drainage problems. There's a small button on the bottom but it doesn't seem to make any difference .
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-09-2007, 12:32 AM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
If the disposer is making a humming noise, that means it's jammed. Unplug the disposer and inspect inside again to make sure there are no foreign objects. You can then release the disposer and plug it back in.
How to release a garbage disposer:
There is a small hole on the bottom of the disposer, right in the center and near the red button you were talking about. Insert a 1/4 inch Allen (hex) wrench (typically supplied with the disposer, can be purchased from most hardware stores) in the hole and move it back and forth until it moves freely. Plug the disposer back in and try it with the water running (you should not use a disposer without water running through it).
Hope this helps.
  #3 (permalink)
Old 10-18-2007, 03:23 PM
wdanielstrans@comcast.net wdanielstrans@comcast.net is offline
Junior Member
wdanielstrans@comcast.net is on a distinguished road
Default
garbage disposal was running but when i cut it off it jammed tried to un jam it using tool to turn but it is just locked when i reset it it just humms before it trips
  #4 (permalink)
Old 11-06-2007, 12:21 AM
Administrator
APP Team
Default
Sounds like it's still jammed. With the disposer power cord still unplugged, check inside for any foreign objects. Try to unlock using the tool again...
  #5 (permalink)
Old 12-22-2007, 10:44 AM
justinfb@optonline.net justinfb@optonline.net is offline
Junior Member
justinfb@optonline.net is on a distinguished road
Default
Quote:
reply; your disposer has a small tool that can crank the the disposer manually. if the disposer does not turn freely, there is someting stuck in the blades. you may be able to loosen this up by turning the tool back and and forth. i have replaced the disposer once onlyto find out that the motor was running well after i had taken in out and saw someting stuck in the blades. mymotor was humming also.
  #6 (permalink)
Old 03-03-2008, 08:50 AM
charrie charrie is offline
Junior Member
charrie is on a distinguished road
Default
Hope this helps.
If you don't have a tool and you want to try something else take the household broom handle (Long & Strong Everyone has one) turn it upside down and put it in the disposal... find a blade or area where you can rest the handle against and stir until it moves usually like just once or twice with pressure will do it, reset the button on the bottom and your good to go. My dad taught me this trick
  #7 (permalink)
Old 03-03-2008, 08:52 AM
Junior Member
Default
Quote:
Try the unjamming with the end of a broom handle... give a good stir 1 -2 times.. You can tell when it unjams because it willl move, reset it and go.
  #8 (permalink)
Old 05-04-2008, 08:01 AM
mack0196 mack0196 is offline
Junior Member
mack0196 is on a distinguished road
Default Success
Using the allen wrench to crank the disposal manually worked for me. As I unjammed it a bunch of coffee grinds came out. I think it was the collection of coffee that was the source of the problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Died? BZYMOM Dryer Repair 2 10-05-2007 02:22 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
