Discuss
Replacing a leaky disposal with a new one
 in
Garbage Disposer Repair
I had a new sink and sink flange installed last year and the exisiting garbage disposal was reconnected. I want
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Replacing a leaky disposal with a new one
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-01-2007, 01:54 PM
glibritz glibritz is offline
Junior Member
glibritz is on a distinguished road
Default Replacing a leaky disposal with a new one
Model Number: GFC 1000-02   Brand: -other-   Age: More than 10 years
I had a new sink and sink flange installed last year and the exisiting garbage disposal was reconnected. I want to remove the current disposal and reconnect a new one without fussing with the sink flange. I'm pretty handy, but have never replaced a disposal unit.
Since I have the original installation instructions that came with the unit, can the disposal be removed by reversing the installation instructions - meaning, by inserting a screwdriver into something called the, "tightening slot" on the mounting ring and turning the mount ring and disposal clockwise until the unlock position is achieved.
Similarly, the new unit should reconnect with a new fiber gasket, support and mounting rings, and cushion mount in the opposite manner, right?
Thank you in advance for your assistance.
Gary LiBritz
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-02-2007, 05:02 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
You don't have to replace the sink flange, if the old one is in good condition.
As far as I remember the gasket comes with the disposer. Check out the diagram from this post. The flange typically consists of numbers 2 thru 7. Numbers 8 and 9 are part of the disposer. The disposer is secured by locking number 9 in to number 5.
Unplug the old disposer, loosen up the drain pipe connector, then unlock 9 from 5 using an allen wrench or a screwdriver. If your dishwasher drain hose is connected to the disposer, make sure to knock out the drain plug in the new disposer before re-connecting the drain hose. Lock the new disposer in to the flange, re-connect drain (both "out" and dishwasher hose). Turn the faucet on and check for leaks. If none found, plug the disposer cord in and try it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to Replace Bad Bearing/Leaky tub Geor2c Washer Repair 2 09-21-2007 03:02 AM
Leaky Motor Seal boscoe Dishwasher Repair 2 08-24-2007 11:24 AM
removing disposal from sink Carnovallp@hotmail.com Garbage Disposer Repair 1 08-13-2007 12:35 PM
Help with Garbage disposal sounds please zuma Garbage Disposer Repair 1 08-11-2007 05:20 PM
Replacing Pump pdiddy Washer Repair 0 07-23-2007 12:43 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
