Discuss
Disposer works but the water does not drain
 in
Garbage Disposer Repair
The disposer grinds and seems to be working, but the water is not draining. Water drains from the side sink
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » Disposer works but the water does not drain
  #1 (permalink)
Old 10-20-2010, 10:11 AM
Junior Member
itchibahn is on a distinguished road
Default Disposer works but the water does not drain
Brand: -brand-   Age: 5 - 10 years
The disposer grinds and seems to be working, but the water is not draining. Water drains from the side sink which has the same drainage. Is this the problem with disposer or is it the pipe going from the disposer to the drainage clogged up?
I'm going to pickup a liquid draino on the way home. If that don't work, I'll take the pipe out tonight.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HELP: wash cycles won't drain/spin, manual rinse/drain works, manual drain/spin works cosmo99 Washer Repair 1 01-27-2010 11:33 AM
bosch shu9925 - drain pump works, won't drain after cycle mjbarr Dishwasher Repair 0 10-16-2009 01:11 PM
water not getting to hose from pump but water dispencer works not ice maker sharbrat Refrigerator & Freezer Repair 0 07-29-2009 10:38 AM
made clunking sound on ice and water dispenser now iced nor water works crazyman Refrigerator & Freezer Repair 1 09-08-2008 01:12 PM
garbage disposer hums and no longer works blawden Garbage Disposer Repair 1 05-02-2008 12:49 AM
