Appliance Repair Forum
-   Garbage Disposer Repair (http://forum.appliancepartspros.com/garbage-disposer-repair/)
-   -   Disposer works but the water does not drain (http://forum.appliancepartspros.com/garbage-disposer-repair/133928-disposer-works-but-water-does-not-drain.html)
itchibahn 10-20-2010 10:11 AM
The disposer grinds and seems to be working, but the water is not draining. Water drains from the side sink which has the same drainage. Is this the problem with disposer or is it the pipe going from the disposer to the drainage clogged up?
I'm going to pickup a liquid draino on the way home. If that don't work, I'll take the pipe out tonight.
