| » Disposer will not run |
Model Number: GFC530H-00 Brand: GE Age: 1 - 5 years
I have a 5 year old GE disposer that has always worked fine. At the completion of a 3 month kitchen remodel, I was re-installing the disposer under the sink and now it will not work.
I have checked the power connections and they are fine. The reset button is depressed. My voltage tester indicates power to the various wires in the housing so now I am completely lost. Could the motor have siezed up during the downtime? But I would think if that were the case you would at least hear the motor hum and attempt to start. Any help will be greatly appreciated. Thanks Related Models |
I was using a test light. Since my post, I used the broom stick trick and spun the blades. The unit was not jammed and turned freely. Then I tried pluging it in again and sparks flew from the outlet. I think I will just buy a new disposer.
it might not be a bad idea to check the wiring in the outlet as well There is definitely a dead short to ground somewhere you can always hook a cord to disposer and plug into another outlet to verify bad disposer
__________________
| Display Modes | |
| Disposer died! | Leslie | Garbage Disposer Repair | 11 | 10-12-2009 09:08 PM |
| Garbage Disposer | Clifton Addison | Garbage Disposer Repair | 2 | 09-06-2008 12:50 PM |
| Garbage Disposer | Clifton Addison | Garbage Disposer Repair | 1 | 08-29-2008 10:44 AM |
| Garbage disposer | bstoffel | Garbage Disposer Repair | 1 | 07-22-2008 11:51 PM |
| New disposer leaks | David P | Garbage Disposer Repair | 0 | 02-15-2008 12:04 PM |
