Discuss
disposal clogged at dishwasher drain point
 in
Garbage Disposer Repair
my dish washer wont drain so i looked for a clog in the hose. I can not blow air through
Appliance Repair Forum > Appliance Repair Help > Garbage Disposer Repair » disposal clogged at dishwasher drain point
  #1 (permalink)
Old 08-24-2008, 04:17 PM
clecun clecun is offline
Junior Member
clecun is on a distinguished road
Default disposal clogged at dishwasher drain point
Model Number: badger 1   Brand: -brand-   Age: 1 - 5 years
my dish washer wont drain so i looked for a clog in the hose. I can not blow air through the house, houses all clear. I believe there is a check valve in the disposal where the hose hooks up and it is stuck. Any suggestions on getting this valve unstuck.
Related Models
Amana BB20V1E Ref - Bottom Mounts
Amana BB20V1PS Ref - Bottom Mounts
Amana BB20V1S Ref - Bottom Mounts
Amana BB20V1W Ref - Bottom Mounts
Amana BB20VE Ref - Bottom Mounts
Amana BB20VPSE Ref - Bottom Mounts
Amana BB20VSE Ref - Bottom Mounts
Amana BB20VW Ref - Bottom Mounts
Amana BBI20TE Ref - Bottom Mounts
Amana BBI20TL Ref - Bottom Mounts
Amana BBI20TPE Ref - Bottom Mounts
Amana BBI20TPL Ref - Bottom Mounts
Amana BBI20TPSW Ref - Bottom Mounts
Amana BBI20TPW Ref - Bottom Mounts
Amana BBI20TW Ref - Bottom Mounts
Amana BC20B Ref - Bottom Mounts
Amana BC20BA Ref - Bottom Mounts
Amana BC20BC Ref - Bottom Mounts
Amana BC20BG Ref - Bottom Mounts
Amana BC20BL Ref - Bottom Mounts
Amana BC20C Ref - Bottom Mounts
Amana BC20CA Ref - Bottom Mounts
Amana BC20CC Ref - Bottom Mounts
Amana BC20CG Ref - Bottom Mounts
Amana BC20CL Ref - Bottom Mounts
Amana BC20D Ref - Bottom Mounts
Amana BC20DA Ref - Bottom Mounts
Amana BC20DC Ref - Bottom Mounts
Amana BC20DG Ref - Bottom Mounts
Amana BC20DL Ref - Bottom Mounts
Amana BC20E Ref - Bottom Mounts
Amana BC20EA Ref - Bottom Mounts
Amana BC20EC Ref - Bottom Mounts
Amana BC20EG Ref - Bottom Mounts
Amana BC20EL Ref - Bottom Mounts
Amana BC20H Ref - Bottom Mounts
Amana BC20J Ref - Bottom Mounts
Amana BC20K Ref - Bottom Mounts
Amana BC20M Ref - Bottom Mounts
Amana BC20N Ref - Bottom Mounts
Amana BC20TL Ref - Bottom Mounts
Amana BC20TW Ref - Bottom Mounts
Amana BC20W Ref - Bottom Mounts
Amana BC20WA Ref - Bottom Mounts
Amana BC20WAG Ref - Bottom Mounts
Amana BC20WC Ref - Bottom Mounts
Amana BC21V1C Ref - Bottom Mounts
Amana BC21V1W Ref - Bottom Mounts
Amana BC21VC Ref - Bottom Mounts
Amana BC21VL Ref - Bottom Mounts
Amana BC21VW Ref - Bottom Mounts
Frigidaire BCEQ2152ES0 Frigidaire Canada/electric Dryer
Frigidaire BCEQ6100FS0 Frigidaire/dryer
Amana BCI20B Ref - Bottom Mounts
Amana BCI20BA Ref - Bottom Mounts
Amana BCI20BC Ref - Bottom Mounts
Amana BCI20BG Ref - Bottom Mounts
Amana BCI20BL Ref - Bottom Mounts
Amana BCI20C Ref - Bottom Mounts
Amana BCI20CA Ref - Bottom Mounts
Amana BCI20CC Ref - Bottom Mounts
Amana BCI20CG Ref - Bottom Mounts
Amana BCI20CL Ref - Bottom Mounts
Amana BCI20D Ref - Bottom Mounts
Amana BCI20DA Ref - Bottom Mounts
Amana BCI20DC Ref - Bottom Mounts
Amana BCI20DG Ref - Bottom Mounts
Amana BCI20DL Ref - Bottom Mounts
Amana BCI20E Ref - Bottom Mounts
Amana BCI20EA Ref - Bottom Mounts
Amana BCI20EC Ref - Bottom Mounts
Amana BCI20EG Ref - Bottom Mounts
Amana BCI20EL Ref - Bottom Mounts
  #2 (permalink)
Old 08-25-2008, 03:29 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Have you replaced the disposal recently?
  #3 (permalink)
Old 08-25-2008, 06:53 PM
Junior Member
Default
no i just moved into the house. Im thinking about just replacing the unit
  #4 (permalink)
Old 08-25-2008, 07:36 PM
Senior Expert
APP Volunteer
Default
That might be a good idea, if you do make sure to knock the plug for the dishwasher out of the new disposal. I don't know how many calls we've had over the years for that.
  #5 (permalink)
Old 08-25-2008, 08:03 PM
Junior Member
Default
hmm you dont say. I wonder if that could be the problem with mine. I put my finger in the hole for the hose and it feels like there is a plug in there and i cant move it. If the plug was still in there what would be the easiest was to remove it.
  #6 (permalink)
Old 08-25-2008, 08:11 PM
Senior Expert
APP Volunteer
Default
Remove the hose and use a big screw driver & hammer, make sure you get all of the plug out if that's what the issue is.
Hope that helps,
Nat
  #7 (permalink)
Old 08-26-2008, 12:58 PM
Junior Member
Default
it worked like a charm. thanks for your help.
  #8 (permalink)
Old 08-26-2008, 01:16 PM
Senior Expert
APP Volunteer
Default
You're very welcome!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Defrost drain clogged billkenny Refrigerator & Freezer Repair 7 06-07-2008 05:45 PM
Defrost drain clogged billkenny Refrigerator & Freezer Repair 1 06-05-2008 01:52 PM
Clogged Drain Line kenand Refrigerator & Freezer Repair 0 03-29-2008 01:37 PM
InSinkErator Disposal clogged djramb2 Garbage Disposer Repair 2 03-22-2008 07:04 PM
Will not drain, not clogged Jimmy Washer Repair 1 12-02-2007 11:15 PM
