Appliance Repair Forum
-   Garbage Disposer Repair (http://forum.appliancepartspros.com/garbage-disposer-repair/)
-   -   Garbage disposer (http://forum.appliancepartspros.com/garbage-disposer-repair/10139-garbage-disposer.html)
bstoffel 07-22-2008 05:46 PM
Garbage disposer
I turned on disposer tonight and it worked fine as ususal. But after I turned off the switch, the unit continued to run. Had to unplug the unit from the wall under the sink to get it to shut off. I tried it again after 30 minutes and it still continues to run. Whats next, please?
Admin / APP Team 07-22-2008 10:51 PM
Sounds like the on/off switch went bad and is constantly supplying power to the wall socket when ON or OFF. I'd check that first.
