Discuss
Whirlpool refrigerator ice maker problems
 in
Forum Announcements
Hi! I have a Whirlpool model ED22DQXEB01 refrigerator, recently the icemaker started over flowing with water. I replaced the water
Appliance Repair Forum > Appliance Repair Help > Forum Announcements » Whirlpool refrigerator ice maker problems
  #1 (permalink)
Old 06-13-2008, 07:31 AM
rleal79 rleal79 is offline
Junior Member
rleal79 is on a distinguished road
Default Whirlpool refrigerator ice maker problems
Hi!
I have a Whirlpool model ED22DQXEB01 refrigerator, recently the icemaker started over flowing with water. I replaced the water valve that provides the water to the water despenser and the water to the icemaker. The water despenser continues to work but there is no water to the ice maker tray. The hose from the the water valve is not stopped up. I have had this refrigerator about 15 years. I have had to replace the water valve on a yearly basis. I did replaced the full ice maker about three years ago. I dont want to replace the ice maker unless that is the problem? The ice thing that pushes the ice out of the tray is at 12 oclock. I have raised the icemaker arm up and down and nothing happens?
Thanks Rod
  #2 (permalink)
Old 06-13-2008, 07:59 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi Rod,
Perform tests as described in one of our previous posts [URL]http://forum.appliancepartspros.com/refrigerator-freezer-repair/8566-water-ice-maker-quit-working.html[/URL] and post the results.
__________________
  #3 (permalink)
Old 06-14-2008, 10:42 AM
Junior Member
Default
Hi!
performed multimeter test nothing occurred,
Thanks Rod
  #4 (permalink)
Old 06-15-2008, 02:16 PM
Junior Member
Default
does the refrigerator have a breaker or fuse that i can replace. Everything works except the ice maker?
Thanks Rod
  #5 (permalink)
Old 06-15-2008, 05:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If there is no 120VAC between the "L" & "N" test points, remove the ice maker and check the black wire in the ice maker wire harness for continuity. If there is no continuity then the thermal fuse which is spliced into the black wire is open due to excessive heat.
I would recommend to replace the ice maker in such case.
- The part number for the ice maker is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=2984633&&model_id=249048&diagram_id=53350"][COLOR=#0066cc]AP2984633[/COLOR][/URL]
Here are the break down diagrams for the Whirlpool refrigerator [url=http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=53344&&model_id=249048]Model ED22DQXEB01[/url]
__________________
  #6 (permalink)
Old 06-20-2008, 04:07 PM
Junior Member
Default
Hi!
I replaced the ice maker and everything is working fine.
Thanks Rod
  #7 (permalink)
Old 06-20-2008, 05:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Rod,
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are Off
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ice maker problems oldg Refrigerator & Freezer Repair 5 06-16-2008 04:58 PM
problems with ice maker and water dld5258 Refrigerator & Freezer Repair 2 03-20-2008 11:54 AM
Ice Maker problems Charlie L. Refrigerator & Freezer Repair 0 03-11-2008 07:12 AM
Norge Ice maker problems bkricks Refrigerator & Freezer Repair 0 01-18-2008 10:35 AM
Whirlpool Ice Maker Problems ponyboy Refrigerator & Freezer Repair 7 11-14-2007 09:25 AM
