Discuss
Got The Maytag Neptune bearings out
 in
Forum Announcements
Finally got the bearings out. However it is clear to me you gotta take the tub completely out! Pulled the
Appliance Repair Forum > Appliance Repair Help > Forum Announcements » Got The Maytag Neptune bearings out
  #1 (permalink)
Old 04-30-2008, 11:53 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default Got The Maytag Neptune bearings out
Pulled the outer bearing almost all the way out with the modified puller, pounded it out the rest of the way with a steel pipe, turned the tub around and pounded out the really bad inner bearing with a 2 inch pipe and my log splitter. In retrospect, I should have inspected the outer bearing better as it was perfect and pounding it out messed up the bearing cover. I should have just left it in, however leaving it in makes it harder to pound out the inner bearing as the sleeve is in the way. In the future I will use a steel pipe to pound out the inner bearing first and leave the outer bearing in if ok. Hope this info helps someone.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are Off
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Mah3000aww Maytag Neptune/bearings,leak Tinamd Washer Repair 1 02-14-2009 05:50 AM
Replacing Neptune bearings richappy Forum Announcements 1 02-14-2009 05:47 AM
Replacing Neptune bearings richappy Forum Announcements 14 01-17-2009 08:51 PM
maytag/neptune Bill Mahurin Washer Repair 3 06-18-2008 02:51 PM
Maytag Neptune Help SPRNTRCR2 Washer Repair 0 04-25-2008 09:52 PM
