| » Got The Maytag Neptune bearings out |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Finally got the bearings out. However it is clear to me you gotta take the tub completely out!
Pulled the outer bearing almost all the way out with the modified puller, pounded it out the rest of the way with a steel pipe, turned the tub around and pounded out the really bad inner bearing with a 2 inch pipe and my log splitter. In retrospect, I should have inspected the outer bearing better as it was perfect and pounding it out messed up the bearing cover. I should have just left it in, however leaving it in makes it harder to pound out the inner bearing as the sleeve is in the way. Hope this info helps someone.
__________________
- Last edited by richappy : 05-20-2008 at 03:59 AM. |
| Display Modes | |
| maytag/neptune | Bill Mahurin | Washer Repair | 3 | 06-18-2008 01:51 PM |
| Replacing Neptune bearings | richappy | Forum Announcements | 4 | 04-29-2008 12:37 PM |
| Replacing Neptune bearings | richappy | Forum Announcements | 0 | 04-29-2008 03:38 AM |
| Maytag Neptune Help | SPRNTRCR2 | Washer Repair | 0 | 04-25-2008 08:52 PM |
| Mah3000aww Maytag Neptune/bearings,leak | Tinamd | Washer Repair | 0 | 10-01-2007 10:30 AM |
