Discuss
Replacing Neptune bearings
 in
Forum Announcements
To replace the Maytag Neptune rear shell bearings first order the seal and bearings. They will fit MAH 3000 or
Appliance Repair Forum > Appliance Repair Help > Forum Announcements » Replacing Neptune bearings
  #1 (permalink)
Old 04-29-2008, 04:38 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default Replacing Neptune bearings
To replace the Maytag Neptune rear shell bearings first order the seal and bearings. They will fit MAH 3000 or 4000 washers.
The bearings can be ordered from this web site ([url]http://www.vbx.com/PROD/kit7731[/url]) SKF numbers (large bearing SKF6207- Sorry for the partial duplicate, dunno how to remove!
__________________
  #2 (permalink)
Old 02-14-2009, 05:47 AM
neptune help neptune help is offline
Member
neptune help is on a distinguished road
Default
You can also purchase the bearing and seal kit from [url=http://www.neptunebearing.com]NEPTUNE BEARING[/url]. You also get an ebook that has tips for removing the failed bearings and inserting the new ones. You can expect this job to take 2 - 6 hours depending on your tools and machanical ability. There is an easier way... the site mentioned above offers a special tool kit rental that includes the bearings and 12002022 seal kit and it also includes a 14 minutes DVD that shows you how to disassemble the stand alone front loader, replace bearings and install the seal kit. Some folks have stated the DVD is the best tool in the box...
Also, don't forget to replace your door latch wax motor... See [url=http://www.neptunehelpsong.com]MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT + 12002535 WAX MOTOR[/url] for a funny song that explains the faulty door latch wax motor issue. Keep in mind that if you have an earlier MAH3000, you have (3) of those darlings you should proactively replace.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are Off
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Mah3000aww Maytag Neptune/bearings,leak Tinamd Washer Repair 1 02-14-2009 05:50 AM
bearings going bad? badbikers Washer Repair 3 05-17-2008 11:25 AM
The little Neptune that couldn't konbit Washer Repair 1 01-08-2008 09:51 PM
washer sounds like ball bearings are at bottom lalexander Washer Repair 1 01-08-2008 04:34 AM
bearings / seal replace gandra Washer Repair 2 11-03-2007 04:59 PM
