Discuss
frigidaire washer leaking
 in
Forum Announcements
i replaced the transmission and tub bearing (spin bearing) and i have water leaking from the tub around the transmission
Appliance Repair Forum > Appliance Repair Help > Forum Announcements » frigidaire washer leaking
  #1 (permalink)
Old 02-20-2009, 01:35 PM
marcm45 marcm45 is offline
Junior Member
marcm45 is on a distinguished road
Default frigidaire washer leaking
i replaced the transmission and tub bearing (spin bearing) and i have water leaking from the tub around the transmission shaft and running down on the belts and spraying water on the motor.is there some kind of sealer that i need? the washer is a stackable frigidaire gallery series model flse72gcs9
  #2 (permalink)
Old 02-20-2009, 05:20 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
Did you happen to put on a new tub seal ([URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=2142342&&model_id=112055&diagram_id=345460"][COLOR=#800080]AP2142342[/COLOR][/URL]) when you did the transmission? If not, this may be the source of your leak.
__________________
TechnicianBrian
TechnicianBrian.com
AllTechAppliance.com
  #3 (permalink)
Old 02-22-2009, 08:01 AM
Junior Member
Default reply to brian about tub seal
i did not replace the tub seal, but i just ordered one. thanks! do i need to grease any of the parts i replaced(spin bearing, outer tub bearing) or use anything on the tub seal?
  #4 (permalink)
Old 02-22-2009, 08:23 AM
Senior Expert
APP Volunteer
Default
No grease, just make sure the seal is pressed into place or you will put it all back together and hear some rubbing noise. Personal experience.
__________________
TechnicianBrian
TechnicianBrian.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are Off
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire dishwasher won't drain and is leaking water SHS1988 Dishwasher Repair 4 08-18-2009 09:19 AM
Stackable Frigidaire washer is leaking from underneath centerpost/transmission gregrao Washer Repair 1 09-26-2008 03:08 PM
Frigidaire leaking water aenonnenmacher Refrigerator & Freezer Repair 1 07-16-2008 10:44 PM
frigidaire dishwasher leaking heller11 Dishwasher Repair 0 03-14-2008 11:29 AM
Frigidaire washer leaking jpcalkins Washer Repair 1 10-03-2007 04:58 AM
