Discuss
KitchenAid Mixer leaking grease/oil into my batter
 in
Forum Announcements
I own a KitchenAid mixer (model #KP2671XMC) which I purchased on 10/18/04. It has started leaking oil/grease
Appliance Repair Forum > Appliance Repair Help > Forum Announcements » KitchenAid Mixer leaking grease/oil into my batter
  #1 (permalink)
Old 01-26-2009, 10:26 AM
cmdudley@comcast.net cmdudley@comcast.net is offline
Junior Member
cmdudley@comcast.net is on a distinguished road
Default KitchenAid Mixer leaking grease/oil into my batter
I own a KitchenAid mixer (model #KP2671XMC) which I purchased on 10/18/04. It has started leaking oil/grease into my batter. My husband and I removed the piece that attaches to the head to find quite a bit of grease/oil in it. We then removed the cover to the head and believe the oil/grease may be leaking from the housing unit. Perhaps the gasket is damaged? Is there any other reason oil/grease would be leaking from this mixer? And if this is correct, is item #AP4308824 (items 7 & 31 housing) the correct item we need to order from your site? thank you
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are Off
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Mixer rkgray98406 General Talk 0 12-22-2008 07:20 PM
Kitchenaid mixer won't turn on andyb_22 General Talk 3 11-25-2008 02:04 PM
KitchenAid Mixer Field Assembly Stator Janet Graham General Talk 0 04-27-2008 12:35 PM
KitchenAid Mixer K5SS speed tonybodie General Talk 0 03-08-2008 03:30 PM
kitchenaid mixer chaffee050 General Talk 0 12-29-2007 05:35 AM
