Discuss
Cooling problems with Amana side-by-side
 in
Forum Announcements
I have an Amana side-by-side refrigerator (Model SQD26VL) that is not freezing or cooling. Had same problem a
Appliance Repair Forum > Appliance Repair Help > Forum Announcements » Cooling problems with Amana side-by-side
  #1 (permalink)
Old 01-05-2009, 06:34 PM
tsears tsears is offline
Junior Member
tsears is on a distinguished road
Default Cooling problems with Amana side-by-side
I have an Amana side-by-side refrigerator (Model SQD26VL) that is not freezing or cooling. Had same problem a couple years ago. Sears Repair changed thermostat (inside freezer) and it worked better. Began having problem again recently so I replaced thermosat but no luck. The compressor and compressor fan run and freezer coils frost up (first couple of top coils only) and the refrigerator stays cool enough to keep food from spoiling. Can't use freezer at all.
The fan above the freezer coils doesn't run. I'm not sure I have the thermostat hooked up correctly. Does the brown wire coming out of the thermostat go to the fan or the black lead? Or does it matter?
I don't have a tester to see if the fan is bad. Can I take old thermostat harness and cut out the thermostat then hook up fan to see if it works?
  #2 (permalink)
Old 01-05-2009, 06:54 PM
Junior Member
Default
Proper thermostat hookup - the brown wire coming out of the back of the unit should be plugged into which of the 2 brown & brown connectors? If #1 is the connector that has 1 brown wire going directly to the test plug and the other brown wire going to #2 brown/brown connector. #2 connector has 1 brown wire going to #1 connector with 2nd brown wire going directly to thermostat.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are Off
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Motor next to Compressor burnt - Amana Side by Side Refrigerator hlitebrite Refrigerator & Freezer Repair 4 03-03-2009 09:49 AM
Very low cooling on Amana side by side 000071 Refrigerator & Freezer Repair 4 11-25-2008 03:55 PM
Frigidaire side by side refridgerator and freezer not cooling. deggling Refrigerator & Freezer Repair 1 09-30-2008 09:56 PM
Side by Side fridge and freezer not cooling and making no ice! krm208 Refrigerator & Freezer Repair 1 07-11-2008 07:41 PM
Amana side by side freezer not cooling gunner Refrigerator & Freezer Repair 1 12-03-2007 04:30 PM
