Discuss
subzero ice maker not working
 in
Forum Announcements
My Subzero model 550 refrigerator with freezer drawer and ice maker below does not make ice cubes. I'm looking
Appliance Repair Forum > Appliance Repair Help > Forum Announcements » subzero ice maker not working
  #1 (permalink)
Old 10-04-2008, 08:10 PM
liebler liebler is offline
Junior Member
liebler is on a distinguished road
Default subzero ice maker not working
My Subzero model 550 refrigerator with freezer drawer and ice maker below does not make ice cubes. I'm looking for troubleshooting advice. Is it likely the solenoid valve and, if so, where is it located? What else is likely cause?
  #2 (permalink)
Old 02-21-2009, 06:30 PM
Lisena Lisena is offline
Junior Member
Lisena is on a distinguished road
Default
My Subzero model 550 refrigerator with freezer drawer and ice maker below does not make ice cubes. What could it be?
  #3 (permalink)
Old 02-22-2009, 05:00 AM
beenthereagain beenthereagain is offline
Expert
APP Volunteer
beenthereagain is on a distinguished road
Default
the freezer tempature must be around zero F, check that first, too warm and it wont be cold enough,
the water solenoid could be bad, or the ice maker itself is bad.
is there any water in the ice maker, is it frozen? does the ice maker ever turn ?
if there is no ice or water in the ice maker, try pouring some water in it, wait a hour or two and check to see if the ice has dumped . if it did , did it refill with water? no then water fill valve is a good bet . otherwise its the I/M
the fill valve is located under the refrigerator back behind the kick plate. must lay on floor and reach back to get to it , not easy.
  #4 (permalink)
Old 02-22-2009, 09:39 AM
Junior Member
Default
It is a used fridge that we just got. It was a floor model and the ice maker has never been used. Yesterday, we replaced the ice maker, the water valve, the solenoid and the switch from the old fridge where the icemaker was working. None of these things worked. Checked all of the wiring and it all seems fine.
Since the icemaker was never used before could it be some simple switch that needs to be turned on that we are missing?
  #5 (permalink)
Old 02-22-2009, 01:57 PM
Expert
APP Volunteer
Default
what is the tempature in the freezer?
there is a ice on / off switch on the shelf, but I think you said you checked it.
  #6 (permalink)
Old 02-22-2009, 03:48 PM
Junior Member
Default
Don't know the temp of the fridge, but put regular ice trays in and they did freeze quickly. But not sure where the on off switch is that you mentioned. What shelf?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are Off
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Maker not working, water dispenser is working fine Monique Refrigerator & Freezer Repair 11 02-15-2009 04:33 PM
Can I Use A New GE Compressor To Replace Bad In SubZero gjrfixit Refrigerator & Freezer Repair 1 09-10-2008 09:28 PM
ice maker not working. replaced ice maker. still not working. inge Refrigerator & Freezer Repair 0 06-23-2008 10:59 AM
SubZero Frige not cold, but freeze works wasmis Refrigerator & Freezer Repair 3 05-24-2008 11:05 PM
Subzero freezeout Inspector 798 Refrigerator & Freezer Repair 3 11-06-2007 09:50 AM
