Hi, I have a maytag gas dryer that heats for two minutes then stops heating. I wait a couple minutes and restart timer and dryer heats then stops after 2 min. When I set the dryer to operate with the moisture sensor, the time starts at 99 min. The timer used to start at 65 min.
Mike:confused:
