| » Very little heat at any setting |
Model Number: CRER7900ASO Brand: Frigidaire Age: 5 - 10 years
A year ago I replaced the heating element and bearing/bushing kit. The dryer has worked fine. Now the dryer barely heats, I checked the heating element and it is fine. The venting hose is open with no restrictions. No matter what setting the dryer is on there is very little heat. What other parts would most likely cause this.
Did you check the element to be sure it is not grounded or just that it had continuity?
Here is the wiring diagram http://manuals.frigidaire.com/prodin...067000shts.pdf Did you check the element to be sure it is not grounded or just that it had continuity? Have you checked that there is 240 volts at the plug when the dfryer is off and when it is running? Be careful 240 volts is lethal!!!
__________________
Yes it could be the thermostat.
Could also be the fabric selector switch, perhaps it is holding the thermostat's internal heater on all the time. You could unplug the unit and check the switch for closed/open contacts at different settings. Could also unplug one side of the thermostat's heating element, tape up the connector so it cannot short to anything, plug the dryer back in and give it a try. If you now have good heat it is probably the fabric selector switch.
__________________
| Display Modes | |
| No heat and setting dial does not turn | TOG1 | Dryer Repair | 4 | 07-06-2009 09:33 PM |
| no heat-timer doesn't move on PP setting | llyod | Dryer Repair | 3 | 12-24-2008 02:54 AM |
| GE Dryer wil not heat up on anything but timed setting. | todv | Dryer Repair | 0 | 11-16-2008 05:20 PM |
| Gas oven will not heat to setting | darthrethaf005 | Oven Repair (including Ranges and Cooktops) | 1 | 06-12-2008 04:03 PM |
| Bake setting provides no heat | adrielus | Oven Repair (including Ranges and Cooktops) | 6 | 12-18-2007 06:21 AM |
