Meterman
Model Number: DDE5300BALWH Brand: GE Age: More than 10 years
Last week I ordered & received a GE dryer motor kit on your order #401534, P/N AP4295548 (WE17X10010), but there were no wiring hook-up instructions included. The Starter Box terminal numbers are almost impossible to read. I would normally assume that one should hook up the dryer wiring harness to the same starter terminal numbers as appeared on the old starter. However, the terminals on the new starter have a slightly different configuration than the terminals on the old starter. I don’t want to do it wrong: which starter terminal receives the Black (load) wire from the dryer, and can you depict/describe that terminal’s location? And, can you send me a wiring diagram showing the starter terminals with identifying numbers?
Related Models
