| » Dryer stops after a few minutes with heat on - will run continuously with heat off |
Model Number: 110.63942101 Brand: Kenmore Age: 5 - 10 years
This just started today. We set the dryer for a 60 minute run with heat on medium. After three minutes it stops. During those three minutes, it put heat out. If I start it up again, it will run a few minutes and then stop. If I change the heat level to air only, it will run continuously and not stop.
The vent is clean but I've yet to crack open the dryer to see what needs cleaning. Curious if the above symptoms are indicative of anything failing or needing cleaning? Thanks, somegeek Ads By Google Related Models |
| Display Modes | |
| Gas dryer heats up for a couple minutes then no heat + gas smell | keithk78 | Dryer Repair | 2 | 10-19-2009 08:29 PM |
| Dryer starts hot then stops proving heat after 2 or 3 minutes | Murray531 | Dryer Repair | 0 | 09-17-2009 11:21 AM |
| Kenmore dryer starts to heat, makes odd cycle noise and stops heating 2 minutes in | pitcher09 | Dryer Repair | 0 | 08-21-2009 04:46 PM |
| Dryer heats for a few minutes then no heat | BLysek | Dryer Repair | 3 | 01-31-2009 05:55 AM |
| kenmore dryer heat cuts out after a few minutes | stumpedagain | Dryer Repair | 0 | 08-22-2008 07:06 PM |
