Discuss
Taking forever to dry a load
 in
Dryer Repair
My dryer shuts down on its own every 3-4 minutes. There seems to be an excessive amount of heat when
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Taking forever to dry a load
  #1 (permalink)
Old 07-11-2008, 08:09 PM
Junior Member
v b-zone is on a distinguished road
Default Taking forever to dry a load
Model Number: 110c64854301   Brand: Kenmore   Age: 5 - 10 years
My dryer shuts down on its own every 3-4 minutes. There seems to be an excessive amount of heat when you open the door but it does re-start when you push the button.
Related Models
Kenmore 110C66652502 RESIDENTIAL DRYER
Kenmore 110C70832990 GAS DRYER
Kenmore 110C70834990 GAS DRYER
Kenmore 110C79592800 RESIDENTIAL DRYER
Kenmore 110C79722800 RESIDENTIAL DRYER
Kenmore 110C85081400 DRYER
Kenmore 110C85087400 DRYER
Kenmore 110C85088400 DRYER
Kenmore 110C85089400 DRYER
Kenmore 110C87561601 RESIDENTIAL DRYER
Kenmore 110C87562601 RESIDENTIAL DRYER
Kenmore 110C87566601 RESIDENTIAL DRYER
Kenmore 110C87571601 DRYER
Kenmore 110C87572601 DRYER
Kenmore 110C87576601 DRYER
Kenmore 110C92962200 LAUNDRY SYSTEM, WASHER AND DRYER
Kenmore 110C96562500 RESIDENTIAL DRYER
Kenmore 110LGR5644EQ0 GAS DRYER
Kenmore 110S-3904 AUTOMATIC WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110S-4760-1 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 110S-5256 AUTOMATIC WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110S-6070 AUTOMATIC WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110S-7099 AUTOMATIC WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Hoover 111.78400 EXTR-W/FIX & ROT BRUSH,TEMPEST
Hoover 111.78401 EXTR-W/FIX & ROT BRUSH,TEMPEST
Hoover 1110
Amana 1110.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1110.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1110.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 1110.101 MWAVE - FAMILY SIZE (60 HZ)
Amana 11100.A MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 1111WAW RANGE- F/S STD GAS
Magic Chef 1111WAW-L RANGE- F/S STD GAS
Magic Chef 1111WRA RANGE- F/S STD GAS
Magic Chef 1111WRW RANGE- F/S STD GAS
Hoover 1112
Hoover 1113
Roper 1116*0A GAS COOKTOP
Roper 1116W0A GAS COOKTOP
Hoover 1118
Hoover 1120
Hoover 1122
Amana 1125A ROOM AIR CONDITIONER
Amana 1125R ROOM AIR CONDITIONER
Amana 113-3EW ROOM AIR CONDITIONER
Amana 113-3HEW ROOM AIR CONDITIONER
Amana 113-3N ROOM AIR CONDITIONER
Amana 113-3NE ROOM AIR CONDITIONER
Amana 113-3NHE ROOM AIR CONDITIONER
Amana 113-3W ROOM AIR CONDITIONER
Amana 113-5N ROOM AIR CONDITIONER
Amana 113-5NE ROOM AIR CONDITIONER
Amana 113-5NH ROOM AIR CONDITIONER
Hoover 1130
Amana 1130.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1130.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1131.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1131.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 1131.101 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1132
Amana 1132.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 1133HEW ROOM AIR CONDITIONER
Amana 1133W ROOM AIR CONDITIONER
Hoover 1136
Amana 1139.C MWAVE - FAMILY SIZE (60 HZ)
Amana 1139.D MWAVE - FAMILY SIZE (60 HZ)
Amana 11390.A MWAVE - FAMILY SIZE (60 HZ)
Amana 11390.B MWAVE - FAMILY SIZE (60 HZ)
Amana 113W-3EW ROOM AIR CONDITIONER
Amana 113W-3N ROOM AIR CONDITIONER
Amana 113W-3NE ROOM AIR CONDITIONER
Amana 113W-3W ROOM AIR CONDITIONER
Hoover 1140
Hoover 1142
Amana 1144.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1145.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1145.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1146.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1146.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 1146.101 MWAVE - FAMILY SIZE (60 HZ)
Amana 1147.001 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1148
Amana 1148.002 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1149
Amana 1150.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1150.002 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1151
Admiral 1151AA-36 SURFACE UNIT- ELE
Admiral 1151AA-36G SURFACE UNIT- ELE
Admiral 1151AD-30 SURFACE UNIT- ELE
Admiral 1151AD-36 SURFACE UNIT- ELE
Admiral 1151AH-30 SURFACE UNIT- ELE
Admiral 1151AH-36G SURFACE UNIT- ELE
Admiral 1151AJ-30 SURFACE UNIT- ELE
Admiral 1151AL-30 SURFACE UNIT- ELE
Admiral 1151AL-36G SURFACE UNIT- ELE
Admiral 1151WA-36 SURFACE UNIT- ELE
Admiral 1151WA-36G SURFACE UNIT- ELE
Admiral 1151WD-30 SURFACE UNIT- ELE
Admiral 1151WD-36 SURFACE UNIT- ELE
Admiral 1151WH-30 SURFACE UNIT- ELE
Admiral 1151WH-36G SURFACE UNIT- ELE
Admiral 1151WJ-30 SURFACE UNIT- ELE
Admiral 1151WL-30 SURFACE UNIT- ELE
Admiral 1151WL-36G SURFACE UNIT- ELE
Hoover 1152
Hoover 1153
Hoover 1157
Hoover 1159
Hoover 1170
Admiral 1171AF-36GK SURFACE UNIT- GAS
Admiral 1171AF-36K SURFACE UNIT- GAS
Admiral 1171AH-30 SURFACE UNIT- GAS
Admiral 1171AH-30K SURFACE UNIT- GAS
Admiral 1171AH-36GK SURFACE UNIT- GAS
  #2 (permalink)
Old 07-12-2008, 04:14 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Remove the external ducting and see if it now runs till the timer times out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Load Thumping Noise & Unbalanced Condition On GE front load washer Luke Vincent Washer Repair 2 08-06-2009 05:43 PM
Oven taking forever to signal it is preheated gyurkop Oven Repair (including Ranges and Cooktops) 1 07-06-2009 01:53 PM
kenmore dryer taking 3-4 hours to dry load m e matel varecha Dryer Repair 1 06-20-2009 05:56 PM
wash machine will not spin with heavy load and makes a sound like a plane taking off lukasd Washer Repair 0 03-31-2009 04:33 PM
Works well with light load; does not start with full load josealvrz Dryer Repair 5 12-09-2008 01:35 AM
