Discuss
Kenmore 70 Series Gas Dryer - Tumble, No Heat, Dial Advances
 in
Dryer Repair
I have a Kenmore 70 series Gas Dryer. It tumbles but has no heat. I checked the Thermal fuse, internal
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore 70 Series Gas Dryer - Tumble, No Heat, Dial Advances
  #1 (permalink)
Old 05-27-2010, 07:17 AM
Junior Member
otleong is on a distinguished road
Lightbulb Kenmore 70 Series Gas Dryer - Tumble, No Heat, Dial Advances
Model Number: 11072722101   Brand: -brand-   Age: 5 - 10 years
I have a Kenmore 70 series Gas Dryer. It tumbles but has no heat. I checked the Thermal fuse, internal bias thermostat, high limit thermostat, and cycling thermostate. All indicated continuity with the exception of internal bias thermostat where one connection has resistance of 3 ohm. Does that mean it is bad?
Also, I wanted to check the igniter (it glows when start the cycle), heat sensor, and gas coil. However, I was unable to open the front (single panel) of the dryer as I can't reach the two screws on the bottom of the panel. Could you tell me how?
What else can I check to ensure what is needed to replace? Thank you for your help.
Related Models
Kenmore 11072722101 GAS DRYER
Kenmore 11072722102 RESIDENTIAL DRYER
Kenmore 11072724100 GAS DRYER
Kenmore 11072724101 GAS DRYER
Kenmore 11072745100 KENMORE AUTOMATIC WASHER
Kenmore 11072745110 KENMORE AUTOMATIC WASHER
Kenmore 11072745120 AUTOMATIC WASHER
Kenmore 11072745130 AUTOMATIC WASHER
Kenmore 11072765100 KENMORE AUTOMATIC WASHER
Kenmore 11072765200 KENMORE AUTOMATIC WASHER
Kenmore 11072765400 KENMORE AUTOMATIC WASHER
Kenmore 11072765600 KENMORE AUTOMATIC WASHER
Kenmore 11072770100 KENMORE AUTOMATIC WASHER
Kenmore 11072770110 KENMORE AUTOMATIC WASHER
Kenmore 11072770200 KENMORE AUTOMATIC WASHER
Kenmore 11072770210 KENMORE AUTOMATIC WASHER
Kenmore 11072770400 KENMORE AUTOMATIC WASHER
Kenmore 11072770410 KENMORE AUTOMATIC WASHER
Kenmore 11072770600 KENMORE AUTOMATIC WASHER
Kenmore 11072770610 KENMORE AUTOMATIC WASHER
Kenmore 11072774100 KENMORE AUTOMATIC WASHER
Kenmore 11072774110 KENMORE AUTOMATIC WASHER
Kenmore 11072774120 KENMORE AUTOMATIC WASHER
Kenmore 11072774200 KENMORE AUTOMATIC WASHER
Kenmore 11072774210 KENMORE AUTOMATIC WASHER
Kenmore 11072774220 KENMORE AUTOMATIC WASHER
Kenmore 11072774400 KENMORE AUTOMATIC WASHER
Kenmore 11072774410 KENMORE AUTOMATIC WASHER
Kenmore 11072774420 KENMORE AUTOMATIC WASHER
Kenmore 11072774600 KENMORE AUTOMATIC WASHER
Kenmore 11072774610 KENMORE AUTOMATIC WASHER
Kenmore 11072774620 KENMORE AUTOMATIC WASHER
Kenmore 11072775100 KENMORE AUTOMATIC WASHER
Kenmore 11072775110 KENMORE AUTOMATIC WASHER
Kenmore 11072775200 KENMORE AUTOMATIC WASHER
Kenmore 11072775210 KENMORE AUTOMATIC WASHER
Kenmore 11072775400 KENMORE AUTOMATIC WASHER
Kenmore 11072775410 KENMORE AUTOMATIC WASHER
Kenmore 11072775600 KENMORE AUTOMATIC WASHER
Kenmore 11072775610 KENMORE AUTOMATIC WASHER
Kenmore 11072775810 KENMORE AUTOMATIC WASHER
Kenmore 11072780100 KENMORE AUTOMATIC WASHER
Kenmore 11072780110 KENMORE AUTOMATIC WASHER
Kenmore 11072780120 KENMORE AUTOMATIC WASHER
Kenmore 11072780200 KENMORE AUTOMATIC WASHER
Kenmore 11072780210 KENMORE AUTOMATIC WASHER
Kenmore 11072780220 KENMORE AUTOMATIC WASHER
Kenmore 11072780400 KENMORE AUTOMATIC WASHER
Kenmore 11072780410 KENMORE AUTOMATIC WASHER
Kenmore 11072780420 KENMORE AUTOMATIC WASHER
Kenmore 11072780600 KENMORE AUTOMATIC WASHER
Kenmore 11072780610 KENMORE AUTOMATIC WASHER
Kenmore 11072780620 KENMORE AUTOMATIC WASHER
Kenmore 11072784100 KENMORE AUTOMATIC WASHER
Kenmore 11072784110 KENMORE AUTOMATIC WASHER
Kenmore 11072784120 KENMORE AUTOMATIC WASHER
Kenmore 11072784200 KENMORE AUTOMATIC WASHER
Kenmore 11072784210 KENMORE AUTOMATIC WASHER
Kenmore 11072784220 KENMORE AUTOMATIC WASHER
Kenmore 11072784400 KENMORE AUTOMATIC WASHER
Kenmore 11072784410 KENMORE AUTOMATIC WASHER
Kenmore 11072784420 KENMORE AUTOMATIC WASHER
Kenmore 11072784600 KENMORE AUTOMATIC WASHER
Kenmore 11072784610 KENMORE AUTOMATIC WASHER
Kenmore 11072784620 KENMORE AUTOMATIC WASHER
Kenmore 11072784820 KENMORE AUTOMATIC WASHER
Kenmore 11072785100 KENMORE AUTOMATIC WASHER
Kenmore 11072785110 KENMORE AUTOMATIC WASHER
Kenmore 11072785200 KENMORE AUTOMATIC WASHER
Kenmore 11072785210 KENMORE AUTOMATIC WASHER
Kenmore 11072785300 AUTOMATIC WASHER
Kenmore 11072785310 AUTOMATIC WASHER
Kenmore 11072785320 AUTOMATIC WASHER
Kenmore 11072785330 AUTOMATIC WASHER
Kenmore 11072785340 ELECTRIC WASHER
Kenmore 11072785400 KENMORE AUTOMATIC WASHER
Kenmore 11072785410 KENMORE AUTOMATIC WASHER
Kenmore 11072785600 KENMORE AUTOMATIC WASHER
Kenmore 11072785610 KENMORE AUTOMATIC WASHER
Kenmore 11072785700 AUTOMATIC WASHER
Kenmore 11072785710 AUTOMATIC WASHER
Kenmore 11072785720 AUTOMATIC WASHER
Kenmore 11072785730 AUTOMATIC WASHER
Kenmore 11072785740 SEARS ELECTRIC WASHER
Kenmore 11072791100 KENMORE AUTOMATIC WASHER
Kenmore 11072791110 KENMORE AUTOMATIC WASHER
Kenmore 11072791200 KENMORE AUTOMATIC WASHER
Kenmore 11072791210 KENMORE AUTOMATIC WASHER
Kenmore 11072791400 KENMORE AUTOMATIC WASHER
Kenmore 11072791410 KENMORE AUTOMATIC WASHER
Kenmore 11072791600 KENMORE AUTOMATIC WASHER
Kenmore 11072791610 KENMORE AUTOMATIC WASHER
Kenmore 11072791800 KENMORE AUTOMATIC WASHER
Kenmore 11072792100 KENMORE AUTOMATIC WASHER
Kenmore 11072792200 KENMORE AUTOMATIC WASHER
Kenmore 11072792400 KENMORE AUTOMATIC WASHER
Kenmore 11072792600 KENMORE AUTOMATIC WASHER
Kenmore 11072793100 KENMORE AUTOMATIC WASHER
Kenmore 11072793200 KENMORE AUTOMATIC WASHER
Kenmore 11072793400 KENMORE AUTOMATIC WASHER
Kenmore 11072793600 KENMORE AUTOMATIC WASHER
Kenmore 11072802100 GAS DRYER
Kenmore 11072802101 GAS DRYER
Kenmore 11072802102 RESIDENTIAL DRYER
Kenmore 11072812100 DRYER
Kenmore 11072812101 GAS DRYER
Kenmore 11072822100 DRYER
Kenmore 11072822101 GAS DRYER
Kenmore 11072822102 RESIDENTIAL DRYER
Kenmore 11072824100 DRYER
Kenmore 11072824101 GAS DRYER
Kenmore 11072824102 RESIDENTIAL DRYER
Kenmore 11072832100 GAS DRYER
Kenmore 11072832101 GAS DRYER
Kenmore 11072842100 DRYER
Kenmore 11072842101 GAS DRYER
Kenmore 11072852100 DRYER
Kenmore 11072852101 GAS DRYER
Kenmore 11072854100 DRYER
Kenmore 11072854101 GAS DRYER
  #2 (permalink)
Old 05-29-2010, 10:26 PM
Junior Member
topher23 is on a distinguished road
Default RE: kenmore 70 series
I'm in the same boat as you right now, except so far I've replaced the solenoid valves and the ignitor on my 70 series. Still no luck getting the fire to light. In response to what you should be looking for, check out this website: How To Fix a Gas Dryer - Gas Dryer Repair Guide - ACME HOW TO.com - If I'd found this earlier I may have had better luck figuring out exactly what to replace.
At least on my dryer, the bottom of the front panel wasn't actually screwed on, but held in place by... crap, it's late and I can't remember what the blasted things are called. Anyway, the front panel slides off if you pull up on it.
Last edited by topher23 : 05-29-2010 at 10:31 PM. Reason: answered front panel removal question
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 70 series - No heat, won't shut off c1eddy Dryer Repair 17 07-08-2017 09:24 AM
Kenmore Gas Dryer with not heat - 70 series abengoa Dryer Repair 0 03-12-2010 05:06 PM
kenmore 80 series dryer won't heat Dhodge Dryer Repair 1 11-11-2009 09:12 PM
dryer will heat but not spin- kenmore 70 series model abengoa Dryer Repair 1 09-14-2009 08:54 PM
Gas dryer...tumble, no heat, igniter OK spark3542 Dryer Repair 13 10-03-2008 11:14 AM
