Discuss
Dryer stopped
 in
Dryer Repair
Suddenly stopped working. Replaced 30 amp fuses at indoor box. Checked outlets. Ads By Google Related Models Whirlpool  RED4440SQ0  29"electric
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer stopped
  #1 (permalink)
Old 05-23-2010, 06:15 PM
Junior Member
Noiraigue is on a distinguished road
Default Dryer stopped
Model Number: RED4440sq0   Brand: Roper   Age: 5 - 10 years
Ads By Google
Related Models
Whirlpool RED4440SQ0 29"electric Dryer
Whirlpool REE1600P
Whirlpool REE1600P1
Whirlpool REE1600P2
Whirlpool REE1600P3
Whirlpool REE1700P
Whirlpool REE1700P1
Whirlpool REE1700P2
Whirlpool REE1700P3
Whirlpool REE22303 24" Freestanding Range Easy - Clean Oven Coil Cooktop
Whirlpool REE23000
Whirlpool REE31300
Whirlpool REE32302 30" Electric Range Coil Cooktop E - Z Clean Oven
Whirlpool REE33000
Whirlpool REE34001
Whirlpool REE6700P
Whirlpool REE6700P1
Whirlpool REE6700P2
Whirlpool REE6700P3
Whirlpool REE6700P4
Whirlpool REE6700W
Whirlpool REE6700W2
Whirlpool REE6700W3
Whirlpool REE6700W4
Whirlpool REE950PW
Whirlpool REE9600W
Whirlpool REE970PW
Whirlpool REE970PW1
Amana REF120905C5E Room Air Conditioner
Amana REF120905C5E RE Room Air Conditioner
Amana REF120905C5ER Room Air Conditioner
Amana REF120905C5ER R Room Air Conditioner
Amana REF18090C5E Room Air Conditioner
Amana REF18090C5E REV Room Air Conditioner
Amana REF18090C5ER Room Air Conditioner
Amana REF18090C5ER RE Room Air Conditioner
Amana REF24080C5E Room Air Conditioner
Amana REF24080C5E REV Room Air Conditioner
Amana REF24080C5ER Room Air Conditioner
Amana REF24080C5ER RE Room Air Conditioner
Thermador REF30
Thermador REF30QB PRIOR TO S/N 9708
Thermador REF30QB S/N 9708 & UP
Thermador REF30QW PRIOR TO S/N 9708
Thermador REF30QW S/N 9708 & UP
Thermador REF30RS PRIOR TO S/N 9707
Thermador REF30RS S/N 9707 & UP
Frigidaire REG34NL1 Frg(v2) / Electric Range
Frigidaire REG34NL2 Frg(v4) / Electric Range
Frigidaire REG34NW1 Frg(v1) / Electric Range
Frigidaire REG34NW2 Frg(v3) / Electric Range
Frigidaire REG36AA2 Frg(v4) / Free Standing Electric Range
Frigidaire REG36AA3 Frg(v4) / Electric Range
Frigidaire REG36AA4 Frg(v9) / Electric Range
Frigidaire REG36AA5 Frg(v3) / Electric Range
Frigidaire REG36AA6 Frg(v8) / Electric Range
Frigidaire REG36AF2 Frg(v5) / Free Standing Electric Range
Frigidaire REG36AF3 Frg(v3) / Electric Range
Frigidaire REG36AF4 Frg(v8) / Electric Range
Frigidaire REG36AF5 Frg(v2) / Electric Range
Frigidaire REG36AF6 Frg(v7) / Electric Range
Frigidaire REG36AH2 Frg(v6) / Free Standing Electric Range
Frigidaire REG36AH3 Frg(v5) / Electric Range
Frigidaire REG36AH4 Frg(v10) / Electric Range
Frigidaire REG36AH5 Frg(v4) / Electric Range
Frigidaire REG36AH6 Frg(v9) / Electric Range
Frigidaire REG36AL2 Frg(v7) / Free Standing Electric Range
Frigidaire REG36AL3 Frg(v2) / Electric Range
Frigidaire REG36AL4 Frg(v7) / Electric Range
Frigidaire REG36AL5 Frg(v5) / Electric Range
Frigidaire REG36AL6 Frg(v10) / Electric Range
Frigidaire REG36AW2 Frg(v8) / Free Standing Electric Range
Frigidaire REG36AW3 Frg(v1) / Electric Range
Frigidaire REG36AW4 Frg(v6) / Electric Range
Frigidaire REG36AW5 Frg(v1) / Electric Range
Frigidaire REG36AW6 Frg(v6) / Electric Range
Frigidaire REG36CAA2 Frg(v9) / Free Standing Electric Range
Frigidaire REG36CAA3 Frg(v3) / Electric Range
Frigidaire REG36CAA4 Frg(v8) / Electric Range
Frigidaire REG36CAA5 Frg(v3) / Electric Range
Frigidaire REG36CAA6 Frg(v8) / Electric Range
Frigidaire REG36CAF2 Frg(v10) / Free Standing Electric Range
Frigidaire REG36CAF3 Frg(v2) / Electric Range
Frigidaire REG36CAF4 Frg(v7) / Electric Range
Frigidaire REG36CAF5 Frg(v2) / Electric Range
Frigidaire REG36CAF6 Frg(v7) / Electric Range
Frigidaire REG36CAH2 Frg(v11) / Free Standing Electric Range
Frigidaire REG36CAH3 Frg(v4) / Electric Range
Frigidaire REG36CAH4 Frg(v9) / Electric Range
Frigidaire REG36CAH5 Frg(v4) / Electric Range
Frigidaire REG36CAH6 Frg(v9) / Electric Range
Frigidaire REG36CAL2 Frg(v12) / Free Standing Electric Range
Frigidaire REG36CAL3 Frg(v5) / Electric Range
Frigidaire REG36CAL4 Frg(v10) / Electric Range
Frigidaire REG36CAL5 Frg(v5) / Electric Range
Frigidaire REG36CAL6 Frg(v10) / Electric Range
Frigidaire REG36CAW2 Frg(v13) / Free Standing Electric Range
Frigidaire REG36CAW3 Frg(v1) / Electric Range
Frigidaire REG36CAW4 Frg(v6) / Electric Range
Frigidaire REG36CAW5 Frg(v1) / Electric Range
Frigidaire REG36CAW6 Frg(v6) / Electric Range
Frigidaire REG38BLL1 Frg(v2) / Electric Range
  #2 (permalink)
Old 05-26-2010, 04:56 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL RED4440SQ0 29"electric Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/w...%208576817.pdf
Were the fuses blown?
Did you have the correct power at the plug? L1 to L2 240 volts also L1 to Neutral and L2 to Neutral 120 volts
Most likely possibilities are the door switch or thermal fuse (Item 7 in Section 3)
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer stopped running Robin Edgar Dryer Repair 11 08-14-2009 10:55 AM
Dryer stopped heating Tchamp Dryer Repair 1 03-25-2009 05:36 PM
dryer stopped crashtotheend Dryer Repair 1 12-30-2008 06:48 AM
Gas dryer stopped working riverasol Dryer Repair 0 12-04-2008 08:45 PM
Dryer Stopped And Will Not Restart goatman_24 Dryer Repair 1 09-13-2007 02:19 AM
