| » Need help with dryer |
Model Number: LER5636EQ3 Brand: Whirlpool Age: 5 - 10 years
I'm not sure if my heating element is out or not. I still have heat but I have to run the dryer 2-3 cycles in order to dry one load of clothes all the way. I cleaned out the lint traps and don't know if it could just be a heating element. Does anyone here know? Thanks for the help!
Very rare a thermostat fails like this, you may have a burnt wire or your dryer is overheating. Remove ducting from dryer, stick a thermometer in the duct and run dryer. Post the temperature.
In addition to all above:
Most likely the problem is clogged up vent outside the dryer. All moister stays inside the dryer due to insufficient air flow causing long time to dry. Disconnect the vent hose from the back of the dryer and run a couple loads with the hose disconnected. You should see a big difference. Good luck. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
| Display Modes | |
