| » Frigidaire Gas Dryer No Heat |
Model Number: FDG336RES1 Brand: Frigidaire Age: 5 - 10 years
Dryer stopped drying clothes even thought cycle runs complete. Replace Ignitor and it seems to run for about 15 minutes then stopped getting heat. I tested the Heat Control Thermostat - its closed, Tested flame sensor and its also closed, Tested safety thermostat its also closed. Checked all the venting to make sure no clogs
I am thinking coils (Gas Valve) ? Running out of ideas ? . Thanks, Ads By Google Related Models |
I decided to run some more tests. I can see the ignitor glow and the first time it ignited a flame which lasted 1-2-minutes.. Then I stopped the dryer to repeat the test and ignitor glowed but no flame... Repeated test and no flame even though ignitor glowed.
I tested the flame sensor by removing the wires (be careful their is voltage as dryer is plugged in) and ran a cycle then touched the wires together and the ignitor glowed (It stayed a glow as long as the wires were touching) but no flame. This leads me to strongly believe the gas valve coils are not working 100% of the time. If I have a glowing ignitor that does not ignite I must have no gas present ? So as a novice I ask what killed the flame on the first test ? What is causing no flame present most of the time ? I think I am going to go with bad coils ? Any expert advice ? Thanks, |
I THINK I'VE DEVISED A WAY TO FULLY TEST ONE BUT COULD USE INPUT FROM SOMEONE SMART HERE. SHOULD FLAME SENSOR HAVE ZERO RESISTANCE (FULL CONTINUITY) UNTIL EXPOSED TO FLAME (OR INTENSE LIGHT ie 200 WATT LIGHT BULB TO BENCH TEST) FOR 15-30 SECONDS AT WHICH POINT YOU CAN FEEL A "CLICK" INTERNALLY AND THE RESISTANCE GOES WAY UP ? AFTER ALL, THE INTENT SEEMS TO BE TO ALLOW BURNER TO LIGHT BY OPENING GAS VALVE FOR SOME PERIOD OF TIME (HOW LONG ?) AND CUT POWER TO VALVE IF NO FLAME IS DETECTED. ANYONE KNOW IF THE MAIN TIMER IS INVOLVED HERE OR IF IT IS ALL DONE WITH SENSOR AND VALVE ? I'M WORKING ON A WHIRLPOOL NOW AND EACH PART CHECKS OUT OK BUT IT ONLY LIGHTS THE FIRST TIME AT CYCLE START THEN ONCE FLAME GOES OFF IT WON'T RE-LIGHT. (CAN'T TELL HOW LONG AFTER START THAT OCCURS)
Quote:
It looks to me that you are on the right track and the problem is a bad coils. - The coil kit Part number: AP2150379 Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FDG336RES1 Frg(v1) / Gas Dryer | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Most likely the problem with your dryer is a bad coils. You can use the same coil kit for Whirlpool dryer because they are identical. - The coil kit Part number: AP2150379 Gene.
__________________
I ordered new coils and will post update after installing them. I do have a dumb question. When I removed the front panel of the dryer the tumbler sags. I noticed the inside of the front cover lost all it's paint by rubbing on the felt seal which is rusty color on one side.
I am thinking the bearing is broke that holds the tumbler and that's why its sagging ? Would I need a bearing kit and is this easily replaced ? AP2142648 Thanks, |
More likely the problem is a worn out front felt seal with glides (#20 & #21 on the diagram).
- The upper felt seal Part number: AP2150497 - The lower seal Part number: AP2143044 Gene.
__________________
__________________
Okay the new coils arrived in just 2 days (super fast ground shipping).
I installed them in under 5 minutes and the dryer is working great... The part was less than $20 and the Dryer is working very well. Thanks to this site and the expert Mediator for the advice. Thanks. |
| Display Modes | |
| Frigidaire Dryer that won't heat | huha69 | Dryer Repair | 7 | 10-18-2010 09:21 AM |
| No Heat in Frigidaire dryer | mzakal | Dryer Repair | 1 | 04-12-2010 06:04 AM |
| Frigidaire Dryer - No heat! | jbeaucha | Dryer Repair | 1 | 08-30-2009 03:29 PM |
| Frigidaire dryer won't heat | MotormanMarc | Dryer Repair | 1 | 06-29-2009 01:08 PM |
| frigidaire gas dryer has no heat | chevyguy | Dryer Repair | 0 | 03-01-2008 10:06 PM |
