Discuss
GE Electric dryer
 in
Dryer Repair
How would I know if I have to replace the motor? When you press the start button it makes a
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE Electric dryer
  #1 (permalink)
Old 05-15-2010, 01:30 PM
Junior Member
tvtaz is on a distinguished road
Default GE Electric dryer
Brand: GE   Age: 5 - 10 years
How would I know if I have to replace the motor? When you press the start button it makes a humming sound. The belt is taut around the drum soIdon't think that is the reason the drum isn't turning.
  #2 (permalink)
Old 05-17-2010, 02:50 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it.
If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp.
If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK.
This may take 2 people
Open the door
Manually hold the door switch closed
Push the start button and manually rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 5 12-09-2013 06:43 PM
electric dryer rashminpathak@hotmail.com Dryer Repair 1 11-09-2009 03:42 PM
ge electric dryer gdmonk Dryer Repair 1 08-21-2009 04:34 PM
Electric Dryer Edonik Dryer Repair 1 01-28-2009 11:57 AM
Gas dryer to electric dryer convertion. Fhabeeow Dryer Repair 1 01-08-2008 07:49 PM
