Discuss
Gas dryer starts, heats for about a minute, shuts off..
 in
Dryer Repair
I just replaced the motor on this dryer and put everything back together. It started right up. I heard the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas dryer starts, heats for about a minute, shuts off..
  #1 (permalink)
Old 05-12-2010, 02:19 PM
Junior Member
redeyedog is on a distinguished road
Default Gas dryer starts, heats for about a minute, shuts off..
Model Number: LGR3624EQ0   Brand: Whirlpool   Age: 5 - 10 years
I just replaced the motor on this dryer and put everything back together. It started right up. I heard the click to allow the gas to come in, then it ignited. I felt heat but must say it felt like it was getting too hot. After about a minute, it clicks and shuts off.
To eliminate the new motor, I put the timer on "Fluff Air" which does not use any heat at all. The motor ran, drum turned flawlessly for 20 minutes without cutting off. No smell.
I have replaced the coils on this unit years ago when there was a similar issue with the heating. Do the coils go out often? Should I change them again. I know these gas heating elements have a bunch of electronics constantly checking each other to keep things safe. What temperature does the heat cutoff at?
Ads By Google
Related Models
Whirlpool LGR3624EQ0
Whirlpool LGR3624EQ1
Whirlpool LGR3624EQ2
Whirlpool LGR3624JQ0
Whirlpool LGR3624JQ1
Whirlpool LGR3624JQ3 29" Gas Dryer
Whirlpool LGR3624PQ0 29" Gas Dryer
Whirlpool LGR3624PQ1 29" Gas Dryer
Whirlpool LGR3634EW0
Whirlpool LGR3634EW1
Whirlpool LGR3634EW2
Whirlpool LGR3634EW3
Whirlpool LGR3634JW0
Whirlpool LGR3634JW1
Whirlpool LGR3634JW2
Admiral LGR3725ADC Range - S/c F/s Gas
Whirlpool LGR4434AN0
Whirlpool LGR4434AN1
Whirlpool LGR4434AQ0
Whirlpool LGR4434AQ1
Whirlpool LGR4434AW0
Whirlpool LGR4434AW1
Whirlpool LGR4436AN0
Whirlpool LGR4436AW0
Whirlpool LGR4600PQ0 29" Gas Dryer
Whirlpool LGR4600PQ1 29" Gas Dryer
Whirlpool LGR4624BN0
Whirlpool LGR4624BN1
Whirlpool LGR4624BN2
Whirlpool LGR4624BQ0
Whirlpool LGR4624BQ1
Whirlpool LGR4624BQ2
Whirlpool LGR4624BW0
Whirlpool LGR4624BW1
Whirlpool LGR4624BW2
Whirlpool LGR4624DQ0
Whirlpool LGR4624DQ1
Whirlpool LGR4624DZ0
Whirlpool LGR4624DZ1
Whirlpool LGR4634BQ0
Whirlpool LGR4634BQ1
Whirlpool LGR4634BQ2
Whirlpool LGR4634DQ0
Whirlpool LGR4634DQ1
Whirlpool LGR4634DZ0
Whirlpool LGR4634EQ0
Whirlpool LGR4634EQ1
Whirlpool LGR4634EQ2
Whirlpool LGR4634EQ3
Whirlpool LGR4634EW0
Whirlpool LGR4634EZ0
Whirlpool LGR4634EZ1
Whirlpool LGR4634EZ2
Whirlpool LGR4634EZ3
Whirlpool LGR4634JQ0
Whirlpool LGR4634JQ1
Whirlpool LGR4634JQ2
Whirlpool LGR4634JQ3 29" Gas Dryer
Whirlpool LGR4634JT0
Whirlpool LGR4634JT1
Whirlpool LGR4634JT2
Whirlpool LGR4634JT3 29" Gas Dryer
Whirlpool LGR4634JZ0
Whirlpool LGR4634JZ1
Whirlpool LGR4634PQ0 29" Gas Dryer
Whirlpool LGR4634PQ1 29" Gas Dryer
Whirlpool LGR4634PT0 29" Gas Dryer
Whirlpool LGR4634PT1 29" Gas Dryer
Whirlpool LGR5434AN0
Whirlpool LGR5434AW0
Whirlpool LGR5600HQ0
Whirlpool LGR5600HZ0
Whirlpool LGR5600JQ0
Whirlpool LGR5600JQ1
Whirlpool LGR5600JT0
Whirlpool LGR5600JT1
Whirlpool LGR5620KQ0
Whirlpool LGR5620KQ1
Whirlpool LGR5620KQ2 29"gas Dryer
Whirlpool LGR5624BN0
Whirlpool LGR5624BN1
Whirlpool LGR5624BN2
Whirlpool LGR5624BW0
Whirlpool LGR5624BW1
Whirlpool LGR5624BW2
Whirlpool LGR5624DQ0
Whirlpool LGR5624DQ1
Whirlpool LGR5624DW1
Whirlpool LGR5624DZ0
Whirlpool LGR5624DZ1
Whirlpool LGR5634AN0
Whirlpool LGR5634AQ0
Whirlpool LGR5634AQ1
Whirlpool LGR5634AQ2
Whirlpool LGR5634AW0
Whirlpool LGR5634DQ1
Whirlpool LGR5634EQ0
Whirlpool LGR5634EZ0
Whirlpool LGR5634LQ0
Whirlpool LGR5635LQ0 29"gas Dryer
Whirlpool LGR5635LQ1 29"gas Dryer
Whirlpool LGR5636DW0
Whirlpool LGR5636DW1
Whirlpool LGR5636EQ0
Whirlpool LGR5636EQ1
Whirlpool LGR5636EQ2
Whirlpool LGR5636EQ3
Whirlpool LGR5636EZ0
Whirlpool LGR5636EZ1
Whirlpool LGR5636EZ2
Whirlpool LGR5636EZ3
Whirlpool LGR5636JQ0
Whirlpool LGR5636JQ1
Whirlpool LGR5636JT0
Whirlpool LGR5636JT1
Whirlpool LGR5636KQ0
Whirlpool LGR5636KQ1
Whirlpool LGR5636KT0
Whirlpool LGR5636KT1
Whirlpool LGR5636LG0
  #2 (permalink)
Old 05-12-2010, 02:50 PM
Junior Member
Default
Not totally sure but this might be a false call. When the dryer was cutting out, I had the exhaust running against the backwall. Then I noticed that there is a little, round thermostat mounted on the back cabinet at the bottom, in between the blower and the heat intake.
So, I put the exhaust pipe back on, channeling the heat outdoors (like it's supposed to) and then watched the dryer run. The burnmer cycled on and off 3 times without turning the dryer off.
At this point, I think the thermostat was just doing it's job and turning off the dryer because too much heat was collecting in back of the unit.
Any ideas? Everything seems to be working well.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool gas dryeR burner shuts off after a minute jason5406 Dryer Repair 12 10-31-2011 01:20 PM
dryer starts then shuts off vtp1957 Dryer Repair 7 12-17-2009 01:53 AM
starts, shuts off one minute millerr Washer Repair 1 09-11-2009 03:56 PM
Kenmore gas dryer starts, heats, shuts off early jcpendergast Dryer Repair 2 08-17-2009 02:25 PM
amana dryer heats for a minute josh79 Dryer Repair 7 09-09-2008 06:44 PM
