Please help. Our dryer just died. We have checked and rechecked fuses. Before it stopped running, the last cycle of clothes, the buzzer went off 3 or 4 times...which is highly unusual. Please, is this most likely the timer? We have no money for a repairman.:confused:
Start by checking to see if you have the proper voltage at the outlet. If you do, you'll want to check the integrity of the door switch and the start switch, as well as the timer.
