| » Replaced Control Panel, still no input signal |
Model Number: MDG5500AWW Brand: Maytag Age: 1 - 5 years
My dryer was making a weird chirping noise for a couple of weeks. Then it wouldn't respond to keypad at all.
I ordered the control panel from your company. The panel I receved is part number: AP3882440 (33003028) I replaced the part and still I am getting no input. No button responds at all, period. My old control board has what looks like an overheated spot on the top right where the 4 little resisters are. The old control panel has the number: 63717810 on it, so I'm wondering if I received the correct part. OR Could the actual pad with the buttons be messed up too? Thanks for any help you can offer. R LeGris Related Models Last edited by rlegris : 07-02-2008 at 01:23 PM. |
I guess I just send this board back to you as I am assuming it is defective since no one has any other suggestions....
I had thought the customer support here was pretty good, that is why I ordered from your company. I can see I was mistaken. |
Are you getting any indication that there is power to the dryer. IE lights anything?
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
Dumb question but has to be asked, did you make sure to connect the ribbon cable?
__________________
It seams unlikely that the panel is bad, usually a panel will stop functioning a button or 2 but not the whole panel. I would take a closer look at the ribbon cable connection, and if all seems ok then your board you put in is probably bad. The only other thing I can suggest is to make sure you have proper voltage going to the board. Make sure you have 120v going into the board.
__________________
Yes, it's 120. Dryer worked fine for years, just started with that weird chirp noise, then one day, the buttons just stopped working. All indications were to replace the control board.
The ribbon cant fit more perfect, so I'm going to assume the control board I received is defective. Unless the ribbon can go bad.... |
| Display Modes | |
| Dishwasher N/F; Electronic Control Replaced | Strong | Dishwasher Repair | 1 | 09-30-2009 10:35 AM |
| Hot Surface Signal Light | Tigerest45 | Oven Repair (including Ranges and Cooktops) | 2 | 01-02-2009 06:55 PM |
| Replace control panel or just control panel housing? | Max Strano | Dishwasher Repair | 1 | 08-26-2008 07:02 PM |
| signal | sheldonbabendure | Dishwasher Repair | 0 | 06-13-2008 10:29 AM |
| Replaced Control Board | mikeinftw | Oven Repair (including Ranges and Cooktops) | 2 | 06-07-2008 02:24 PM |
